Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 01-04-2003, 23:24
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I know that feeling-
It was our first match at Philly- we had homecourt advantage and all, and we really wanted to do well..
anyway, we hit the stack first, went over, and then somehow flipped over. This never happened at Chesapeake so we were all bummed.. Our arm driver decided we had nothing to lose, and tried to flip us over.. Amazingly, the chippy pulled through, and we came back to life.
We ended up winning this match with 213 QP's
Unread 01-04-2003, 23:49
codeoftherobot's Avatar
codeoftherobot codeoftherobot is offline
Safety General
FRC #1097
codeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura about
I saw at one regional the robot freak out, spin around for about a minute on the top of the ramp then start to smoke as though it was about to blow up. Our team happened to have treads and when we hit other teams at high speeds, we ran right over them and left tread tracks all over their robot. One team we faced in Sacramento came to Silicon Valley and it still had the same scuff marks.
Sacramento Regional 2003 -Rookie All-Star Award
Silicon Valley Regional 2003 -Rookie All-Star Award
Sacramento Regional 2004 -Autodesk Visualization Award
Sacramento Regional 2004 -Regional Engineering Inspiration Award
Silicon Valley Regional 2004 -Johnson & Johnson Sportsmanship Award
Cal Games 2004 - Finalist (thank you 968 and 114!)
Sacramento Regional 2005 - #1 Seed Team Regional Finalist (with 254 and 114)
Sacramento Regional 2005 - Johnson and Johnson Team Sportsmanship Award
Unread 02-04-2003, 00:10
D. Gregory's Avatar
D. Gregory D. Gregory is offline
FIRST Junkie
no team (UHS Wolfpack)
D. Gregory is an unknown quantity at this point
Send a message via ICQ to D. Gregory Send a message via MSN to D. Gregory
In the practice rounds, our robot was so tippy that when our autonomous took us straight into the wall, we tipped. When we went straight over the ramp and hit boxes, we topped. Of course, we rebuilt our robot and finished 10th without a single tip in qualifying matches.
Duct tape is the force that holds the universe together. Everywhere except FIRST that is.
Unread 02-04-2003, 00:17
Safety General
FRC #1097
What did your team do to fix it. Add stabilizers or just cut the height in half?
Unread 02-04-2003, 00:21
Parks Parks is offline
Parks is an unknown quantity at this point
since people have mentioned all the damage, I felt like commenting. Some people dislike this game because it is too intense. The way I look at it, it forces the teams to create a robot that can not only do a task and do it well, but also stand up to the abuse of use. This, I believe, has a really good real world application to it. It forces teams to consider the entire design process, and not just finish when the robot is built. I feel that this game, more than others, brings forth the true meaning and practices of engineering.
This is also why I had such an awesome time at the regional. I can't wait until Houston.
Andrew Parks
CrescentSchool Robotics
Co-Construction Head and Driver
Team 610
2002 Regional Champs
2002 Engineering Inspiration
2003 Regional Chairman's Award
Unread 02-04-2003, 03:24
Winged Globe Winged Globe is offline
Don't Panic
AKA: Xiao-Yu Fu
FRC #0481 (The Hitchhikers)
Winged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of light
Send a message via AIM to Winged Globe
I have a very strong feeling this was us at Sacramento ... We are not going to be drilling near those speed controllers again!
Unread 02-04-2003, 08:07
D. Gregory's Avatar
FIRST Junkie
In order to fix our robot, we removed all our devices and were left with a speed, manoeuverable, strong, extrusion box on wheels. We eneded up at 87 lbs so we added 10lbs of steel tube to the bottom of our bot to lower the CoG even more.
Unread 02-04-2003, 14:07
at the Canadian regional there were 8 seeding round matches per team - that means you spend:
16 minutes on the playfield in action and
36 hours in the pits (if you stay as late as possible)
all the magic on our team happened in the pits. After the buckeye regional we discovered (by watching the videos) that our flying squirrel was only takeing out two columns of boxes, and it was folding way back.
So we came up with a hindged version on paper, brought all the raw materials with us, and made it 5.5 feet wide in the pits on thursday.
we also moved our battery from standing up vertical on top of the frame, to lying horizontal below the frame. That took two days to implement - we didnt get it attached till saturday morning (after a collision had knocked a hole large enough in our plexiglass panel to run the battery wire through :c)
we also had to repair damaged transmissions between matches 5 or 6 times. We are going to open a transmission repair shop "your tranny fixed in 30 minutes or less, or your next ones FREE!"
Team members who sit in the stands all day miss out on the real action - and the pits REALLY come alive after 6PM on thursday night :c)
Unread 21-02-2004, 02:20
c01100011 c01100011 is offline
c01100011 is an unknown quantity at this point
Send a message via AIM to c01100011
Re: The coolest thing in the world!
When our grabber arms broke at Suffolk last year and they were flying around. I think the limit switch wiring was the only thing that held them on. We dragged them up the ramp, lucky they didn't turn us off for protruding through it. As I remember we mad it up on the ramp fine put down our suction cups and got the points.
i own autocad or wait nevermind it is the other way around
What's The Coolest Thing A Team Can Give Out? Joe Matt General Forum 496 03-04-2008 10:22
What's 'Right' with this world archiver 2000 2 23-06-2002 22:37
PERFECT WORLD archiver 1999 3 23-06-2002 22:20
FIRST Spirit to the world!!! Tomas General Forum 3 12-04-2002 13:25
Coolest thing I've seen Deej General Forum 5 17-03-2002 20:54
