Go to Post Okay, okay, I'll bring your Krispy Kremes to the Championships ... I bought them right after the '03 Championships ... I'm sure they are still in the attic - Natchez [more]
Unread 27-02-2016, 12:23
Jackson Hogan Jackson Hogan is offline
FRC #5090
Jackson Hogan is an unknown quantity at this point
Is it legal to use IP camera's on your robot?
Our team was trying to find a way to use multiple cameras.
Unread 27-02-2016, 13:07
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Is it legal to use IP camera's on your robot?
The RoboRio has two USB type A ports on it, could you not just use two USB webcams? Or are you looking to use more than 2 cameras?
To answer your specific question though, IP cameras are allowed (Implied per R60), but you may need to add a separate Ethernet switch to be able to connect more than one to the robot at a time. Also keep in mind bandwidth restrictions if you plan to have multiple cameras running simultaneously. We've had problems running even one camera at a decent framerate with the fields bandwidth limitations in place.
Unread 27-02-2016, 13:15
FRC #5090
yea, we could... But we dont know how to do it that way. (We don't know how to show two cameras on the dashboard).
Unread 27-02-2016, 13:29
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Ok, so this thread shows how to use 2 USB cameras connected to the roboRIO. Just remember to change the camera name strings accordingly.
To find the names of the cameras connected to the roboRIO, connect them both, turn on the roboRIO and access the web interface from a computer with a compatible browser (IE9, Mozilla Firefox). In the sidebar you'll see all the connected devices. Find the cameras and copy their names to the code. Look at the attached image in case of doubt.
Finally, in your SmartDashboard, insert a USB Webcam Viewer and you're done!
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 27-02-2016, 13:36
AKA: Lucas Alvarez
BTW: If you really want to use the IP cameras, a recent team update enabled teams to use the radios from previous years.
Team Update 11, R57, Blue Box
Louisiana Jones's Avatar
Louisiana Jones Louisiana Jones is online now
Jason Jones
AKA: Jason Jones
FRC #1806 (S.W.A.T.)
Louisiana Jones will become famous soon enoughLouisiana Jones will become famous soon enough
As a switch, specifically. (Wireless functionality needs to be disabled)
Unread 27-02-2016, 13:47
FRC #5090
We are using labview not Java/C++
