Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-02-2016, 15:35
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Can't find correctly sized gear
In order to fix our intake, we've opted to change to a P60 Gearbox instead of PG27. However, our current gear setup uses these two gears. The big issue we're facing is that we either need to replace that first gear with something that can fit a P60 and a correctly sized machine key, or find a new combination of gears that can do the same thing and hold our hex shaft. I've also tried finding alternate shafts for the P60 that would work with the current gear setup but to no avail.
Could someone help me find some gears or a new shaft?
EDIT: For reference, A P60 has a 1/2 inch shaft and an 1/8th inch keyway.
