Go to Post The GDC probably took bets on how many posts they could get off of a random CAD render, and bonus points for how many people go insane from thinking about it! :yikes: - gallo26 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-02-2016, 16:06
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Can't find correctly sized gear
Originally Posted by Joe Johnson View Post
McMaster sells a the right gear 32T, 20DP, 14.5Deg Pressure angle
But you will have to open up the hole to 1/2 inch (it comes 3/8 stock) and then you have to buy this collar & this broach & shim and broach the 1/8" keyway in the 1/2" hole.
Alternatively, you could use a VersaPlanetary but you'd have to change center distances because you still wouldn't have a gearset that added up to the same number of teeth (29+32=61 -- Vex doesn't sell many/any gears with odd numbers of teeth).
Actually, I just now realized that I assumed that you wanted the P60 to be driving the 32T gear. If that is wrong. Then I will have to change my answer.
Good luck.
Dr. Joe J.
Nope, that's correct. So I would buy that gear, drill a 1/2 inch hole in it and then .. what exactly? I've never worked with collars or broaches to my knowledge.
