Go to Post Yes, an expanded FIRST will look far different than it does today. - GaryVoshol [more]
Unread 02-21-2016, 10:00 AM
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Please Help ME !!!!!!!
We are programming our intake we got the intake to bring the ball in but we cant seem to get it to work to shoot it back out Here is the code.
Teleop Code
public void teleopPeriodic() {
while (isOperatorControl() && isEnabled()) {
Fulldrive.setSafetyEnabled(true);
Fulldrive.arcadeDrive(Drivestick);
if(controlStick.getRawButton(3)) {
IntakeBall.ShootBall(0.5);
else if(!controlStick.getRawButton(3)) {
IntakeBall.ShootBall(0.0);
if(controlStick.getRawButton(2)) { // Takes Ball
IntakeBall.GrabBall(0.5);
else if(!controlStick.getRawButton(2)) {
IntakeBall.GrabBall(0.0);
} Timer.delay(0.01); } }
I made a class for the intake/ shooter
import edu.wpi.first.wpilibj.Talon;
public class IntakeBall {
private Talon leftWheel, rightWheel;
public IntakeBall(Talon leftWheel, Talon rightWheel) {
this.leftWheel = leftWheel;
this.rightWheel = rightWheel;
public void GrabBall(double speed) { // Gets Ball in
leftWheel.set(-speed);
rightWheel.set(speed);
public void ShootBall(double speed) {
leftWheel.set(speed);
rightWheel.setInverted(true);
Unread 02-21-2016, 11:22 AM
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Please Help ME !!!!!!!
Try changing ShootBall to be the same as GrabBall but with the speed signs flipped so the motors go in opposite directions.
Unread 02-27-2016, 05:05 PM
lakecat's Avatar
lakecat lakecat is offline
Cat Expert
AKA: Tristan Thompson
FRC #2635 (Lake Monsters)
lakecat is an unknown quantity at this point
I would avoid setting rightWheel to inverted, it may be the source of some of your errors. In fact, it seems like you don't need grabBall at all, considering it does the same thing as shootBall, except with a different method of getting one wheel to move the opposite direction of the other. It looks like you need to negate your input to shootBall in your first if statement.
