Go to Post If 100 people from ChiefDelphi all wrote one full article on something that they are an 'expert' in, FIRSTwiki would be even better. - artdutra04 [more]
Unread 27-02-2016, 17:15
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Help Needed With Vex Ball Shifter
Hey all -
We need some help. We recently had to replace the Ball Shifters on our competition robot with some single speed dual cims due to the fact that we couldn't get the shifters to work. I'm hoping that you might be able to help us get them working.
When we run them, we are getting a loud clicking sound and a lot of stuttering in the bot - especially when we try to turn. The same issue doesn't exist with the single speed. We initially thought it was the scrubbing due to the fact that we only had four wheels, but we no longer do.
I know this isn't a lot of description, but I'm not sure what other info to provide. If anyone could help walk me through this I'd be appreciative.
Best -
Daniel
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 27-02-2016, 17:20
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Help Needed With Vex Ball Shifter
Originally Posted by MysterE View Post
Hey all -
Best -
Daniel
Need more data:
  • Number of motors on each side.
  • Total Ratio from motor to wheels (3 numbers, 2 with the shifter set up, 1 with the single speed set up)
  • Size of the wheels
  • Also, what type of wheels are we taking about (let me guess 8" Pneumatic Tires from AndyMark).
  • Can you tell us about the pneumatic system you are using to power the shifting actuators? Are you sure it is working right? Is there another air actuator that you have that is working properly?
Dr. Joe J.
Team #88, TJ2
Unread 27-02-2016, 17:43
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
Ok -
So - I'm going to post the info I have. I'll be honest - I'm not sure how to calculate the gear ratios.
Ball Shifter is 3 cim Ball Shifter using 2 Cims with a 2.65 spread. The pinion gear attached is 12 tooth and the wheels have a 30 tooth gear on them.
The Single Speed is a WCP with 2 motors with a 44:30 ratio attached to the same gears on the wheels.
Wheels are 12 inch pneumatic taped to reduce friction.
As far as we can tell the air actuator is working correctly - we are using another to launch our catapult and that is working properly.
Let me know what else you need.
Thx,
Daniel
Coach. D. Eiland
Unread 27-02-2016, 17:45
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Ok -
Thx,
Daniel
Does the clicking noise happen all the time? We got the same noise in our ball shifters in the offseason, but only when we tried shifting *with low air*. What pressure are you using to shift?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 27-02-2016, 17:55
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
It clicks at random times. It just seems not to give it enough power but I can't figure why not.
Coach. D. Eiland
Unread 27-02-2016, 18:16
AKA: Dr. Joe
FRC #0088 (TJ2)
Ok -
Thx,
Daniel
Vexpro 3CIM Shifter with 2.65 spread:
CIM Shaft=Motor to ShifterShaft1:
12:50
ShifterShaft1 to ShifterShaft2 = Output:
50:34 High Gear
34:50 Low Gear
ShifterShaft2 to Wheel
12:30
Overall Ratio (High Gear):
(50X34X30)
------------- = 7.1:1
(12X50X12)
Overall Ratio (Low Gear):
(50X54X30)
------------- = 18.8:1
(12X30X12)
WCP with 30:44:
12:50
30:44
12:30
Overall Ratio:
(50X44X30)
------------- = 15.3:1
(12X30X12)
Plugging these numbers into JVN's spreadsheet (again, I say, this spreadsheet should be required to buy a gearbox from AndyMark or Vex) with a 12" wheel you are going to have (adjusted top speed) of
Shifter Low Gear: 12fps
Shifter High Gear: 31.8fps
Single Speed: 14.8fps
That 31.8fps is MONSTER. WAY TOO FAST. Seriously. That is almost certainly your problem. I suppose that the clicking you heard was the CIRCUIT BREAKERS not the shifters. You should probably get ratios more like 19:1 in high gear and 50:1 in low gear with those 12" wheels.
Dr. Joe J.
Team #88, TJ2
Unread 27-02-2016, 18:29
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Check the small plastic coupling between the cylinder and the shifter gear shaft. We've had bad issues with the outermost retaining ring staying seated when shifting from low to high. Our cylinder pulled the ring off and left the shaft in between low and high. The ratcheting noise we got (sounds similar to the clicking one you describe) is from our shifter "hanging" between gears since it cannot shift into high. It is difficult to see it under load, but if you can watch it shift with wheels off the ground, you may be able to eliminate the issue we had. As mentioned above, the pressure while shifting is also very important as that can be a possible cause as well.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 27-02-2016, 18:46
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Hey all -
Best -
Daniel
After reading through all the blog post and looking at the calculations Dr. Joe did it is likely you are tripping your snap action breakers or your roborio is browning out.
The biggest thing that jumped out at me was when you switched from a 6 cim drive train to a 4 cim drive train you said it quit doing it. Your total amperage draw should have gone down when making this switch. You said it does it more when you try to turn, this is likely because you are drawing more power due to the increase friction on the wheels while turning. Our robot does the same thing with the ball shifters on a dead battery (10 volts). IF you look at your RSL (robot signal light) does it flicker as well when it happens? if so you are simply drawing to much electrical current at once for the system. The new gearbox with less motors just reduced your overall power required to run the drive train.
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 27-02-2016, 19:02
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
We have this problem on our practice bot also when in low gear. What is your pneumatic pressure? And are you using chain or belts?
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 27-02-2016, 20:37
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Echoing these comments, I've run into issues with similar clicking noises when running the shifting pneumatics working pressure at ~40psi. The issue virtually disappears when the pressure is increased to 50-60psi
Unread 27-02-2016, 22:08
Mihir Juvvadi Mihir Juvvadi is offline
Drivetrain Design Lead
FRC #0192 (GRT)
Rookie Year: 2015
Mihir Juvvadi is on a distinguished road
Its been said by more than a few others, but I am almost positive your problem is simply low pneumatic pressure to your shifting actuators.
The clicking noise you described comes when the shifting shaft is not in full engagement into one or the other gears, and the balls interact with the contours in the gears.
In addition, this diagnosis would cause the jitteriness you described when driving. If the shifting actuator is not getting its full pressure (60 psi), then the shifting cluster could easily start to disengage.
Check pressure regs etc. on the bot, and it should help.
