Go to Post When the going gets tough, the smart keep their GP. - Libby K [more]
Unread 02-27-2016, 07:45 PM
Daynater Daynater is offline
Team Googler/Chief Delphier
FRC #4132 (Scotbots)
Daynater is an unknown quantity at this point
Powered cart?
'Ello everyone. Im curious because I've found nothing about it in the rules, is it legal/ok to have a battery and a DC/AC converter on the robot's cart for charging laptops/phones etc? The cart battery would never be powering anything robot related other than the driver station.
Unread 02-27-2016, 07:51 PM
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Powered cart?
Yes, the use of a battery to charge the driver station via an inverter is fine. It is also fine to charge laptops/phones from
it.
Be careful with the output side of the inverter(120v bit), as especially being on a robot cart, it could easily be abraded, scrapped and even accidentally cut. You'll need to be super careful to make sure this can't happen.
Something like this?
http://www.chiefdelphi.com/forums/sh...ghlight=tablet
Andymark sells an inverter with an SB50 Anderson already attached
http://www.andymark.com/product-p/am-0626.htm
Unread 02-27-2016, 08:02 PM
Re: Powered cart?
Thanks for the quick reply and advice! Incidentally I have a converter I was going to use, and was going to buy one of these to connect it. http://www.amazon.com/NOCO-GC018-Soc...4M7 J8NTN6K16
Does it have to be an Anderson connector?
Unread 02-27-2016, 08:10 PM
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Powered cart?
No, it can be whatever you want. Anderson connectors make it easy to use the robot batteries you already have though.
We use older, more worn out batteries to run our inverter, not 'competition grade' ones but they all have common connectors and chargers.
Unread 02-27-2016, 08:17 PM
pilleya's Avatar
Elec+Mech
Re: Powered cart?
Thanks for the quick reply! incidentally i have a converter i was going to use, and was going to buy one of these to connect it. http://www.amazon.com/NOCO-GC018-Soc...4M7 J8NTN6K16
That product seems to only have a 15amp fuse, that would only a max 180watt power draw. I'm not sure the power of your inverter, but the fuse might be too small.
You probably want to be charge the battery with the same charger as you use for your other comp batteries. FIRST requires that all robot battery chargers have a SB50 connected, so yes I would suggest that you would need to put a SB50 connector onto the inverter cable
I find it is relatively easy to crimp one of the SB-50 connectors on to 16awg, I did it for some battery chargers last season, if you don't have the crimping tool you can do it in a vice with a screwdriver and a hammer and then fill the lug up with solder( to strengthen and guarantee connection), as it is only a low current draw application
Re: Powered cart?
Thank you.
