Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
Unread 27-02-2016, 21:32
tdbroun tdbroun is offline
AKA: Tim Brounscheidel
FRC #1507 (Warlocks)
tdbroun is an unknown quantity at this point
3D printable radio case
One of our students created this radio case to hold the power connector in. This can easily become dislodged during a defense crossing, so it could prove very useful. Attached is the file to print it and a photo of it mounted in our 'bot.
The round ears on the corners are to prevent warping during printing. Just cut them off when it's done. The bottom is open to allow attachment of the radio with fasteners, velcro, etc... The radio just snaps in.
Happy printing.
File Type: zip Radio Case With Warp Protection Circles.zip (94.9 KB, 143 views)
Unread 27-02-2016, 21:38
Raggy Raggy is offline
FRC #1768 (Robo Chiefs)
Team Role: Electrical
Rookie Year: 2015
Raggy is an unknown quantity at this point
Re: 3D printable radio case
Did you guys do this because of how the internal's of the radio are open to the outside or is it for mounting puposes?
Unread 27-02-2016, 21:49
just to hold the power connector in
Unread 27-02-2016, 22:01
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Please let this student have my thanks, we didn't realize we had this problem until yesterday. We were doing a promotional event and after we went over the rock wall about 15-18 times the power connector simply fell out. This will be very useful. I hope that the student doesn't mind if I edit the drawing a little bit to make it more suitable for mounting .
Unread 27-02-2016, 22:52
I'm not sure we ever connected anything to our router's power port. We've been using passive Power Over Ethernet from the beginning. The network cable isn't prone to coming out due to vibration. My feeling is that any shocks that would dislodge it are likely to dislodge the innards of the router as well.
Unread 27-02-2016, 22:54
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Don't quote me on this, but one of our mentors told us that it was against the rules to use POE with the router for competition....
Unread 28-02-2016, 00:14
Ask that mentor to quote the rule which prohibits it. Then have him read the second paragraph in the blue box following <R43>:
Note that this prohibits using any POE Injector device to power the
radio, but does not prohibit using any PASSIVE CONDUCTORS to
inject the VRM power into an Ethernet cable plugged into the radio port
labeled “18-24v POE”.
We took a short Ethernet "port saver", exposed the wires in the middle, and spliced in a power pigtail to go to the VRM.
Unread 28-02-2016, 00:25
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Sounds like a great solution. We wanted to do that, but didn't, because we (apparently mistakenly) presumed that the 12V from the VRM wouldn't successfully power the device in the "18-24v POE" port -- sounds like you've found that putting 12v into the "18-24v" port works A-OK?
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 28-02-2016, 01:04
Originally Posted by Ken Streeter View Post
...we (apparently mistakenly) presumed that the 12V from the VRM wouldn't successfully power the device in the "18-24v POE" port -- sounds like you've found that putting 12v into the "18-24v" port works A-OK?
The port is labeled 18-24v, but the label on the bottom of the router says 12-24v. The open-mesh web site says it's compatible with 12-24v passive POE. Following the suggestion in the <R43> blue box commentary works fine.
If we had a 3D printer, a radio mount with a built-in strain relief for the Ethernet cable is something I'd be asking our students to investigate.
Unread 21-03-2016, 15:00
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
can you give more detail on this?
What wires to splice into, etc?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 21-03-2016, 15:08
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Also, please give us a specific citation to the "port saver" you used, for future reference.
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Unread 21-03-2016, 16:13
There are eight wires in an Ethernet cable, connected to pins 1-8 on the connector. The Ethernet signal is carried on the 3/6 and 1/2 pairs (green and orange wires). For passive POE, pins 4 and 5 (blue) get +12 volts, and pins 7 and 8 (brown) are ground.
(A wire pair is actually one wire of solid color and one white wire with a like-colored stripe.)
You can find more information by doing a web search on "passive power over ethernet".
The ones we are using are from a prior year's First Choice, part number FC14-022. I'm pretty sure they are the same as what is available here: https://www.estoprobotics.com/estore...d&productId=27
Any short Ethernet extension should be usable.
As a proof of concept, I also pulled apart a cheap Ethernet coupler (similar to http://www.cablewholesale.com/produc...mc-8p8c-st.php), stripped the appropriate wires inside it, and soldered on power wires that exit the coupler through a small hole I drilled in the bottom. It would require two Ethernet patch cables to use it, one going to the roboRIO and one to the OM5P.
