Spider-Man style Tower scale
The goals
Hang on the bar Do this in 10s or less Fit on 14in tall robot Proposed solution Take two small Nerf (or similar) guns, and attach grappling hooks and steel cable. Hard mount these to your frame at the corners. At the start of endgame fire both dart guns at the bar. Then use 2 CIMs to winch yourself up 22-28in and hang there. Does any one see any problems related to legality or technical implementation? (Assuming the hooks stay within 15ins of the frame, and are throw at non lethal velocities) |
Re: Spider-Man style Tower scale
Center of gravity issues and the changing of the plane of your 15" rule. If your frame where to change it's orientation you would violate the 15" and incur a penalty.
The frame rule just says that your 15 inch plane rotates with the plane of your robot correct?
But if you do it like this, the distance from your frame would decrease as you climbed
Yes. You would need to make sure that the robot never tips vertically (such that it "drives" up the wall).
We had also considered a system like this, the problem with shooting darts up is that they are unreliable. Instead we are considering a telescoping arm that can just drag a hook up there. The arm doesn't have to be strong since it never takes more than the hook's force. Then in order to stay perpendicular to the wall we are going to mount the cable to the back of the frame as well as the motor.
We haven't been able to test this yet as it is the last thing we would put on our robot given the time. I would recommend that you don't focus on the lifting until you have everything else perfect. The lifting is one of the most difficult challenges and has a very small benefit. I mean you get 10 extra points for adding an entire new subsystem. Either way good luck with this, it will be challenging. |
#7
The other thing is, there is no possible way to get a nerf gun to fire a dart that heavy more than 5 ft (unless you make something known as a pumpsnap)
#8
That is what I was thinking about, with all that added weight from a hook you won't be very accurate and you will suffer from too little power. 5 feet may be good enough to reach the bar, but when I calculated this I couldn't even get that high.
#9
You can make your own nerf-like gun using PVC. I feel like a compressed air system would be illegal though, need to double-check the rules on that.
#14
http://www.nerfitalia.it/wp-content/...RainbowMk2.png |
