Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
Hi! While I did select my webcam from the drop down menu, my laptop still isn't scanning the QR code, no matter how I hold it. Are there webcam requirements for scanning codes, or is there another issue here?
Interesting... Not quite sure why that's happening. Any chance you can screenshot the QR code and send me that image and a copy of your schema file?
There aren't any set requirements, but I have noticed that some webcams do sometimes have problems with the scanning, probably because they don't have high enough resolution. |
Do you need to send data after every match or can you collect data all day and then send it after the day is over?
While you can send data at the end of the day, I would recommend doing it as often as you can. That way if any data were to be lost from the phones, you would not lose as much.
On a slightly different note, this may be a stupid question, but how do I view the data sent to the server? Last edited by tanogirl : 29-02-2016 at 19:45. |
You can export the data with the button in the bottom left corner. It will allow you to save a zip file that contains csv files that have all of the data.
#7
Thanks for letting me know hopefully I can get it up and running for Buckeye Regional
#8
This app is great!
One thing I have a question about is when I create the server I can only connect on my local network. It is using my local ip address instead of my router's public address for the server. Is it possible to use my public address? |
#9
You'd have to set up port forwarding for port 5001 on your router. In theory I don't see why it wouldn't work but in practice i can't promise anything.
#10
One suggestion that I would like to make is this: Is there any possible way you could make it so the server application exports data automatically? That way I could have the server running at home on my PC and it exports data automatically to a folder (and I can have the folder on a cloud drive that I could access remotely either on my phone or on another PC while at competition) Last edited by RWS98 : 03-03-2016 at 22:33. |
#11
Does anyone have any examples of their schemas? I am not well-versed on the creating part haha
#12
I tried this software out today by setting up a basic schema. I was able to successfully upload and export data, but after designing a more complex schema it stopped working. Whenever I go to export data on the server, it crashes after I select where to save it. What could cause this?
#13
I did some more testing and it appears to be a problem with using two different schemas with the same regional. (Causes it to crash while exporting)
#15
That is supposed to be supported. I'll test that out and try to fix the bug.
