Go to Post everyone in FIRST has to do the cha cha slide at least once per season to get it out of their system. Now I can go back to doing it in the privacy of my own car (if you see a red Jeep in CT swerving back and forth don't worry, it's just me doing the slide...)! - KathieK [more]
Unread 02-27-2016, 08:49 PM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Permission denied when pushing code
This popped for us today, any ideas?
Brian K
Team 1225 Robotics Mentor
Unread 02-27-2016, 09:22 PM
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I just got ours to work...but I don't really know what I did.
I reflashed firmware and reimaged the roboRIO multiple times using our driver station Classmate and my programming laptop. No dice.
I swapped the roboRIO with another one - no dice. Same problem.
I got a completely different laptop, updated the WPI plugins, tried to deploy, no dice.
I used the same laptop to reflash and reimage the roboRIO. I deleted the project from the workspace, then reimported it and rebuilt. At this point, it downloaded. I am not even sure that action contributed to the fix.
Unread 02-28-2016, 02:51 AM
O-H
Anyone experiencing problems, please cross-post details to the FIRST Forums thread here - http://forums.usfirst.org/showthread...-During-Deploy.
Time to make it loud.
Unread 02-28-2016, 10:54 AM
AKA: Brad
#0190 ( Gompei and the Herd)
If you're familiar with Linux, could you try ssh-ing to the roboRIO as lvuser and check the permissions and ownership of files in the lvuser home directory and look for anything not owned by lvuser. It seems like somehow something is getting messed up, maybe a a download failing part way through or something.
If not, I would expect that reimaging and being sure to check the reformat box in the imaging tool would get you back. If you do that, be sure to reinstall Java if that's the language you're using.
Brad
Brad Miller
Robotics Resource Center
Unread 02-28-2016, 01:37 PM
SuperBK's Avatar
AKA: BrianK
We SSH'd to the roborio as admin, then did
chmod -R 777 /home/lvuser/
To give all users read, write, and execute permissions to the folder.
lvuser was not the owner of the /home/lvuser/ folder, to we gave all permissions to everybody.
Its now working for us.
Brian K
Unread 02-28-2016, 01:51 PM
LG67 LG67 is offline
LG67 is an unknown quantity at this point
Spent a gazillion hours last night trying to fix the exact same problem and your solution is a life-saver. Thank you
Unread 02-28-2016, 02:34 PM
Next time someone has an issue, please log into the roboRIO run the following command and post the output here.
Log in as admin@roboRIO-<team#>-frc.local with putty or equivilent
Then, run
ls -lah /home/lvuser/
And post the results.
Unread 02-28-2016, 03:25 PM
SuperBK's Avatar
AKA: BrianK
After updating the Eclipse plugins, we were broken again. Something, during the deploy process is TAKING AWAY the permissions for lvuser to the /home/lvuser/ folder. This happens during or before the "killall" command.
Our fix was to modify the build.xml file and add permissions back to the lvuser folder before the copy of the code over. Note that the user "admin" is used to add the permissions back, not "lvuser"
Here is a snippit of the build.xml. We added this part
<sshexec host="${target}"
username="admin"
password="${password}"
trust="true"
failonerror="false"
command="chmod 777 /home/lvuser"/>
               username="admin"
               trust="true"
               failonerror="false"
               command="killall -q netconsole-host || :"/>
  	               username="admin"
  	               trust="true"
  	               failonerror="false"
    <scp file="${wpilib.ant.dir}/robotCommand" todir="${username}@${target}:/home/lvuser/" password="${password}" trust="true"/>
Brian K
Unread 02-28-2016, 03:45 PM
SuperBK's Avatar
AKA: BrianK
I attached my build.xml file. (remove the .txt extension)
Brian K
Unread 02-28-2016, 10:31 PM
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
carrud is an unknown quantity at this point
This partially worked for me. This exact placement did not resolve the Permission Denied, but moving the line to a diff spot in the .xml worked great.
BTW, for others: this .xml for me is in wpilib/cpp/current/ant
Many thanks for posting this fix.
-Clark
Unread 02-29-2016, 03:06 PM
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
I am now getting the Permission Denied feature when trying to deploy. Started today after I allowed eclipse to upgrade from 4.5.1.20150917-1200 to 4.5.1.20160218-0600.
I Tried "reverting" back in Eclipse.
I tried using FileZilla to allow all permissions to home/lvuser. My changes did not seem to stick.
I tried changing changing build.xml that is ..wpilib\cpp\current\ant adding:
<sshexec host="${target}" command="chmod 777 /home/lvuser" failonerror="false" trust="true" password="${password}" username="admin"/>
at random locations.
I tried updating the firmware in the roboRio.
I did not feel comfortable that I did any of the above steps correctly, but I am still unable to deploy code.
I will try deploying with another computer this afternoon.
Unread 02-29-2016, 04:11 PM
SuperBK's Avatar
AKA: BrianK
You may have to ssh to your roboRio first and issue the "chmod 777 /home/lvuser" to give permission to the folder, then run the modified build.xml. . After issuing the command you can do
ls -l /home/lvuser
and see if the permissions are "drwxrwxrwx" to see if your changes take.
Do you need step-by-step instructions on how to ssh to it? I use putty, a ssh client.
After doing that, try deploying again. Post the entire contents of your build log here.
Do you see se the extra chmod command in your build log?
Add exactly this (cut and paste)
username="admin"
trust="true"
failonerror="false"
Above the line
Brian K
Unread 02-29-2016, 05:16 PM
AKA: rod nelson
Thanx Brian,
When I had previously tried to set permissions with filezilla, I had logged on as lvuser. It probably did not the right privileges. Logged on as admin and the permission changes stuck.
Added your "chmod 777" to build.xml and voila.
You will be receiving good karma credits.
Unread 02-29-2016, 05:39 PM
O-H
I THINK THIS IS KEY. The computer that works and deploys code has MARS.1 installed (4.5.1.20150917-1200). The computer that started flaking out and throwing permission denied errors has MARS.2 (4.5.1.20160218-0600), which I installed shortly prior to this problem occurring.
I will use the build.xml hack in an emergency, but I hope the developers investigate this potential blar with Eclipse developers.
Unread 03-01-2016, 12:53 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
We're seeing this same issue here at 116. I wiped out the updated Mars.1 eclipse and installed Mars.2 with the exact same results -- permission denied. I still have the original Mars.1 install package. I'll try that, but I suspect that it will work until the update rolls in.
Mike A.
FRC #116
