Go to Post This reminds me of a sports bar where there's a bunch of games on different TV's. Only this is better because it's FIRST. :D - JackG [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 28-02-2016, 17:13
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: STEM Quiz #1
Originally Posted by GeeTwo View Post
The Vex Versaplanetary gearbox offers single stages ranging from 3:1 reduction down to 10:1 reduction.
Side note: I think it's beautiful that the ratios offered are all clean integer ratios*, not messy repeating decimals. Planetary gear boxes of this variety have single stage ratios of Ring Gear Teeth/Sun Gear Teeth +1. The ring gears on Versaplanetaries are 72 teeth, which has factors 2x2x2x3x3. Using those factors in different combinations results in sun gears of 36, 24, 18, 12, 9, and 8 resulting in 3:1, 4:1, 5:1, 7:1, 9:1, and 10:1 respectively. 6:1 and 8:1 ratios would have required use of prime factors 5 and 7 respectively, which would increase the ring gear tooth count by that many, which is impractical.
*I understand by definition gear ratios are integer ratios, but when reduced to the mechanical advantage factor, only evenly divisible ratios give integer results.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
