Go to Post sheesh, how much more of a nerd can I be? - Libby K [more]
Unread 28-02-2016, 18:15
BBaltrusch BBaltrusch is offline
FRC #4818 (The Herd)
BBaltrusch is an unknown quantity at this point
PDP resistance
Could someone do us a favor and measure the resistance between the + and - terminals on a PDP? Our practice board is 77 ohms. We did have a wiring issue and popped some breakers, worried the board is toast. I know I measured each terminal to chassis on the comp bot before bag and they were fine, think I had several hundred k + to - but not sure. Don't have a 3rd PDP to check.
Unread 28-02-2016, 18:18
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: PDP resistance
We have two out of bag PDPs. I'll check our resistance on Monday when I next get in the shop.
Unread 28-02-2016, 18:56
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: PDP resistance
Do you have any fuses in the PDP? It may be possible that metal shavings are somehow shorting the PDP somewhere. 77 ohms is way too low of a resistance between supply rails. Keep us updated!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 28-02-2016, 19:05
Re: PDP resistance
All breakers/fuses out, all wires disconnected. I opened it up and found a hairline crack in the solder mask over one of the power traces of a circuit that popped a breaker. Looks a little bulged, I can see the copper. Other side of pcb is fine. I'm guessing we're shorting to the ground plane underneath. I think she's dead Jim.
Unread 28-02-2016, 19:16
Re: PDP resistance
I get infinity, but I only went up to the MOhm range.
