Go to Post ....you can't go to a single FIRST event without someone saying "Hey, Look! It's SuperNerd!" - [more]
Unread 28-02-2016, 20:11
christheman200's Avatar
christheman200 christheman200 is offline
Chris Lansdale, Programmer
AKA: Chris Lansdale
FRC #0854 (Iron Bears)
christheman200 is an unknown quantity at this point
SmartDashboard forgetting layout
Hi guys!
SmartDashboard is not saving its layout after shutdown. Even through making a manual save, the created XML file is left blank. Have any of you had this problem or found a solution?
Thanks!
Chris
Unread 28-02-2016, 20:23
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: SmartDashboard forgetting layout
I ran into a similar (maybe the same) problem last week, and the only way I could find to fix it was to recreate the layout from scratch.
To see if it is the same error, run the SmartDashboard from the console and see if it throws a NullPointerException when you try to save. The stack trace could be useful to help figure out the real cause of the problem.
Unread 05-03-2016, 03:41
jmullins16's Avatar
jmullins16 jmullins16 is offline
AKA: Jeff Mullins
FRC #2135 (Presentation Invasion)
jmullins16 is an unknown quantity at this point
We found that more complicated layouts that caused the layout file size to be larger than 8k would not reliably be saved. We were using RobotBuilder and stopped having it create dashboard buttons as a default. This has been true for a couple of years, but we have not had a problem since making simpler layouts.
Unread 05-03-2016, 21:43
Chase Haddleton's Avatar
Chase Haddleton Chase Haddleton is offline
Software Mentor
FRC #3683 (Team D.A.V.E.)
Rookie Year: 2015
Chase Haddleton is an unknown quantity at this point
We found that the "Would you like to save your layout" prompt and the "Save As" menu item to not work; upon restarting SmartDashboard the "default" layout would always exist. Try instead to use the simple "Save" button, we've found that it works reliably on all of our laptops, as well as on the laptops of a few other teams.
