Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 28-02-2016, 20:10
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Visual Tracking Help
Hi this is are teams second year and are first time trying to use visual tracking we are using Java (Eclipse) and our camera is the LifeCam HD-3000. My goal is to be able to find the distance to the high goal that we will be trying to score in. I have tried using Grip but it doesn't seem to have the capabilities to find the distance at the current stage in it development. Should I use OpenCV or some other visual tracking program. Any links to help get started would be appreciative.
Our Camera
https://www.microsoft.com/accessorie...3000/t3h-00011
Thanks
Unread 28-02-2016, 21:33
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Visual Tracking Help
Our Camera
Thanks
We used a Kangaroo and OpenCV I believe... not sure if its working yet as we have had little practice with it.. Seems though to recognize the goal and isolate it just fine.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 28-02-2016, 21:40
FRC #5712
Do you know if you can help me or send me instructions on how you have gotten OpenCV to work. The only instructions I can find are... but they are really old.
http://docs.opencv.org/2.4/doc/tutor...a_eclipse.html
Unread 28-02-2016, 21:43
I'll send a message to a programmer and see if they can PM you.
Unread 28-02-2016, 21:46
FRC #5712
Talking Re: Visual Tracking Help
Thanks a lot for your help.
Unread 28-02-2016, 21:54
No problem I sent the email, you should keep this thread going in case there are any other vision experts as this was our first year with trying to aim with tracking too. I hope it works (have yet to see it though due to lack of practice).
We'll know Thursday. I'm sure he can get you started though.
Unread 28-02-2016, 23:14
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
My team has been able to track both distance and angle to the target pretty reliably based off of GRIP. Search Tower Tracker from the programming subforum, we based our math off of that, but we used GRIP to find the contours.
Unread 28-02-2016, 23:42
FRC #5712
I will look into this for sure I know how to use GRIP but didn't know it was feasible. I'll check back if I have any questions.
Unread 28-02-2016, 23:46
FRC #5712
Once I have the conturs what do I do with them send them to the smartdash board or the driver station or do I have to integrate it into my code first?
Unread 29-02-2016, 08:30
FRC #5712
Does anyone know how after I find the counters and send them to the driver station and the smart dashboard then how I can find the distance.
Unread 29-02-2016, 09:43
barn34's Avatar
barn34 barn34 is offline
Isn't this how Skynet got started?
AKA: William Barnickel
FRC #2481 (Roboteers)
barn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond repute
depends what you mean by 'distance' (which side of the target tracking triangle are you looking for). also, depends on what values you're calculating from the image and how you're calculating the angle to target.
the most general way to explain it is that you know how wide the target is (20 inches). you also know how wide the resolution is for the camera (that depends on the camera you are using and how it's set up). same with the field of view, as that's camera dependent.
you can convert how wide the target is in pixels in your camera image to a distance to that target in inches by doing the trigonometry and using the pixels to inches conversion by keeping in mind that the target is 20 inches wide.
that's probably a bit too ambiguous of an answer, but the specifics depend on how you're initially processing the image and calculating that angle to target.
2016 Einstein Field WORLD CHAMPIONS & Carver Sub-Division Winner (330 & 120 & 1086)
2016 Smoky Mountains Regional Winner (3824 & 4740)
2016 Central Illinois Regional Winner (876 & 2220)
2015 Central Illinois Regional Winner (1756 & 2220)
2015 Rock City Regional Winner (2451 & 1625)
2014 Einstein Field Semi-Finalist & Galileo Division Winner (67 & 973 & 2363)
2014 Wisconsin Regional Winner (1732 & 2202)
--- Industrial Design Award (2010, 2015) ------ Innovation in Control Award (2013, 2014, 2016) ---
--- Quality Award (2015) ---------- Creativity Award (2014) ---------- Visualization Award (2009) ---
Unread 29-02-2016, 10:58
FRC #5712
I am trying to track the front one mostly. I am tracking the area, width, and height the pixels of the tower then would be 1500 pixels. My camera resolution is 720p HD. Don't know then where to go from there.
Unread 29-02-2016, 11:16
barn34's Avatar
of the whole tower? or just the goal target?
Unread 29-02-2016, 13:33
If you know the vertical pixel position of the target in your camera image and the vertical field of view of the camera in both pixels and degrees, you can compute the vertical angle from the camera to the target.
If you know the vertical angle to the target, the height of the target, and the height of the camera, you can compute both the horizontal distance to a point directly beneath the target and the straight-line diagonal distance to the target.
The vertical field of view of the camera in pixels is a constant (720 pixels for a 720p image). The field of view in degrees is also a constant that you can measure. The height of the target is a constant, defined in the field drawings. The height of the camera is something you can define for yourself.
Once you have the location of the target in the image, finding distance is a matter of simple trigonometry.
Unread 29-02-2016, 14:51
FRC #5712
Height of target is = 7ft 1in
Height of camera is = 7in
How do I find the vertical angle to the target and the vertical field of view of the camera in pixels. The camera says that its is a 16:9 widescreen I don't know if that the field of view in degrees or what is.
Sorry I'm brand new to this
Link to camera info is http://www.amazon.com/Microsoft-T3H-.../dp/B004ETQHDM
