Go to Post I always get a little stressed as arm operator, especially with Paul Copioli standing behind me screaming at me. - JohnnyB [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 29-02-2016, 12:14
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Qualitative Scouting?
Originally Posted by Green Potato View Post
Generally speaking, the problem with qualitative information is that different scouts have different reactions on the same event, and some form of training/ rubric is extremely helpful, even 100% necessary if your scouts are, like ours, younger team members.
If you go quantitative, you need to make sure that you can accurately interpret the data you get. If you don't attach any external meaning to a statistic you collect (shots, cycles, etc) it literally isn't a statistic any more, and looses its value as a result. Also, It's a good idea to add a "comments" area: some times, it's not obvious if action X should be counted in statistic Y, so allowing the individual scout to write it down is quite helpful.
You've brought up a couple really good points. Any team looking to do good qualitative scouting should record who is taking what notes. We can go back and see, "okay, this person said this about this team, and this person said this about the same team." This allows us to negate the effects of scouter bias, and discussion between disagreeing qualitative scouters can bring out amazing details on a team's strengths and weaknesses. Also, track the match numbers corresponding to specific notes, this allows you to easily explain anomalies in quantitative performance.
Remember, qualitative data is helpful alone, and so is quantitative data. However, when the two are combined efficiently and effectively, you can derive much more from the data than you could with either one alone.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
[IMG] code is Off
