Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Unread 29-02-2016, 12:47
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Re: Modifying Denso Motors
Originally Posted by Mark McLeod View Post
I go the other way, the window motors have explicit permission to only be modified to remove the locking pins.
The Q&A and your event Lead Robot Inspector will know for sure.
Q-806 in the Question and Answer section would indicate that the gear box can be considered a separate item since it can be removed from the unit and attached to another legal motor. By this reasoning, modifying the gearbox portion of the unit would not be considered as modifying the motor's electrical or mechanical condition.
And yes, I am a Lead Robot Inspector.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
