Originally Posted by Retired Starman
Q-806 in the Question and Answer section would indicate that the gear box can be considered a separate item since it can be removed from the unit and attached to another legal motor. By this reasoning, modifying the gearbox portion of the unit would not be considered as modifying the motor's electrical or mechanical condition.
I disagree.
R30 seems quite clear that the "integral mechanical and electrical system of any motor must not be modified".
Q-806 only says that after the gearbox is fully removed from the window motor it is just a gearbox like any other, and no longer considered a window motor.
I think you should kick this to Al and the Q&A.
