Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 29-02-2016, 14:38
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: New radio question
I have 3 of these new radios.
1. I had to turn off the wireless on my laptop I was using to flash them correctly.
2. I had to flash them to make them compatible with FRC fields (even if they may never see a field).
3. When I flashed the FRC firmware with success on each I accessed the configuration page and confirmed I got the FRC firmware (says FRC in the version).
4. I did not buy these from AndyMark I got mine from Amazon.
5. Crossover/straight through Ethernet cabling did not matter.
6. Use the Ethernet port with the 802.3 in the label.
7. I had no problem setting my team, WPA key or AP/Bridge/Frequency after I got this to work before that - I got success messages on the flash BUT the configuration would not take.
