Go to Post Figure out where you have to start and what end result you want, from there, all you have to fill in is the middle. - Beth Sweet [more]
Unread 02-29-2016, 04:54 PM
MrP_Hack's Avatar
MrP_Hack MrP_Hack is online now
FRC #3414 (Hackbots)
MrP_Hack is an unknown quantity at this point
Re: Navx Trouble - inconsistent connection
Was there ever any resolution in regards to this issue. We purchased two NaxX MXP Boards last year but did not use them until this year. We are seeing disconnects as well. We have boards plugged into RoboRio and also tethered with USB just to make sure. Any assistance would be greatly appreciated. I would be more than happy to get additional details from our Programming Team Leads and Mentors.
Unread 02-29-2016, 05:25 PM
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
The NavX-MXP 2.0 firmware, released in late 2015, fixed an issue with intermittent connectivity under certain conditions, and should address this issue. Instructions for updating the firmware are here: http://navx-mxp.kauailabs.com/suppor...ting-firmware/
