Re: Palmetto Regional Week 0.5
It should provide the exact same amount of protection according to the rules. Are you just pointing out that the refs might not see it if you back up into the outer works rather than shoot as you go through? I think this rule is a critical part of the game and everyone involved needs to understand how closely it's going to be enforced.
Now that I've expressed it clearly, I'm going to post it to Q&A (assuming I don't find it there already). Edit: Q532 seems to cover this pretty clearly. These non-calls were missed, not intentional. Quote:
Not trying to justify the lack of calls, just give an alternative perspective.
*Note: I did not see any of the videos in question where there was a potential G43 penalty that was not called Firstly, please remember that the Ref's are human, and are volunteering their time. Sometimes people make mistakes This year is a complicated year for the Ref's and there is a lot that each ref needs to watch and that visibility might be poor. Remember that the students are the volunteers customer, that means that both the students on *your* alliance AND the students on the *other* alliance. If you back up so that your bumpers are just barely in the outer works and it's not obvious then a ref might miss it. My assessment is that if you are planning to shoot from the outerworks so to take advantage of it's protected zone status, you should make it obvious to the refs that you are in the outerworks. |
This applies also to bots expecting the ref to see "solo" sally door bumps or drawbridge taps...don't count on it. They missed many obvious crossings "no sensors" let alone "tricky" solo ones. Don't count on getting calls or credit. That's a failed assumption in a game as complex as this from a reffing standpoint (and scouting standpoint) I think the refs will as time goes on get the basics down...the rest though is dreaming. Last edited by Boltman : 01-03-2016 at 11:13. |
I agree it is a tough game to ref, and refs will miss things, but it's also their job to enforce the rules as best as possible. If I do my best to make it obvious that my robot bumpers are in the OUTER WORKS, I should expect be protected from interference, regardless of when/how/from what direction I approach the OUTER WORKS. *Disclaimer: My team is not shooting at all, and has a mechanism to open the Sally Port from the neutral zone so as not to rely on the "tap" method.* |
Basically the rule is in place so the other alliance cannot just defend entrances to to "easier" defenses all day and also so they cant trap a bot in a defense... the "shooting protection" is a secondary construct of the rule in the first place...relying on "bumper hang shooting protection" calls is dreaming. To many other things refs have a primary responsibility to track...like basic crossings. These are volunteers and are human with a tough game to call. They let slide many things in Palmetto..probably due to audience game play flow. Just like in NFL holding happens many times a game..gets called a few times. Too many "flags' creates audience fatigue. Last edited by Boltman : 01-03-2016 at 11:50. |
#7
Actually, a well-driven defensive robot could still block the entrance to easier defenses. As long as they are not touching an opposing robot in the outerworks they can still prevent access. |
#8
It shouldn't be. But just be aware that if it's not obvious or a ref didn't see it, they will likely err on the side of not issuing a penalty. So if you want to take advantage of the protection zone, make it obvious that you are in the protection zone.
#10
Refs are human, for sure, but the OUTER WORKS protection is such a key part of the game mechanic this year that a robot anywhere near there should invite some attention from at least one ref, period. Perhaps FIRST needs to consider putting some kind of stripe on the edges of the plastic dividers so the refs can more easily see where the OUTER WORKS starts. Last edited by Nuttyman54 : 01-03-2016 at 13:29. |
#11
This year is so complex "bump hang" is probably really low on any priority list of ref calls. They are not in the middle of the game on every defense. They like both drive teams will have limited visibility and lots of action to take into account. I agree they "should" call it but also see the difficulty in doing so. No instant replay. Last edited by Boltman : 01-03-2016 at 13:38. |
#12
I 100% agree it's on the teams to make it obvious they're within the OUTER WORKS, but a robot within the zone is within the zone, period. If a ref can't see that, it's an issue, shooter or not. There's no "priority" for a call. A robot with bumpers in the zone is TRAVERSING by definition of the rules, regardless of whether or not it's traversing (moving) in a colloquial sense. If refs can't see that occurance, that's a much larger problem than just for shooters trying to shoot from a protected region. Several robots will want to move into the protection of the OUTER WORKS before deploying or moving mechanisms to help them get across the obstacles. For what it's worth, determining protection should be easier this year than in the past, since the refs aren't trying to determine robot contact with a patch or a tape line on the floor with the perspective of looking halfway across the field with parallax. There should be at least two refs with a direct line of sight down the planes which determine the start of the outer works. Time will tell. Palmetto was a very early event, I expect as more refs experience and give feedback on the game, FIRST head refs will improve the guidance to their teams on best operating procedures and how to call things. |
#14
Hello everyone, now that I've had some time to wind down and catch up on my duties post Palmetto I wanted to extend a thank you to everyone who attended or watched the event. Our team had its own challenges at the competition, but we had a blast with everyone we had a chance to speak with. I'd also like to send another thanks to the members of MARS and Garnet Squadron (and other teams I may have missed) for staying after the event and helping us with packing away FIRST's playing field and accessories to be sent off to the next event.
With the new teams at the event we got to see and experience mechanisms we had never attempted to build before. I, personally, was astonished by what some of the teams were able to develop during the short build season. We will be spending our off season learning how to develop those mechanisms with the students so we can be better prepared for games which may benefit from them in the future. Always be prepared! Congratulations to the winning alliance this year! I look forward to seeing how well you guys perform at St. Louis! |
#15
This is a missed call. I'm not blaming anyone and realize this is a nuanced rule, but it should be made a point of emphasis in the next few weeks by FIRST if the calls continue to be overlooked. The potential for penalties is highest around the outerworks and secret passage, these zones will need to be watched closely. Thanks GeeTwo for asking/finding the Q/A for this. (https://frc-qa.firstinspires.org/Que...ot-is-still-in) Again, unclear situations are going to be common, but with a ref standing almost in line with the outerworks, it should be fairly easy for them to call it in cases like the above photo. I also believe that if it does start getting called with frequency the defender will have to play more cautious and that should lead to offense having a bigger window to sit in to shoot. Edit: I think I misread the reply I was quoting. I do agree with making it obvious to the refs, I thought you said you didn't see any cases where it should have be called. Not that you hadn't seen any of the videos where it should have been called. Most of my reply still makes some sense though. So I'll leave it up. Last edited by Keefe2471 : 01-03-2016 at 12:27. Reason: Misread the reply |
