Puncturing Pneumatic Tires
Hello everyone,
Our team has had relatively little experience with pneumatic tires during the competition season. So I wondered how pneumatic tires hold up during competitions. Has anyone experienced flat tires in previous years? I can imagine that the current game will cause even more punctures compared to previous years. Thank you, Floris Team 1389 |
Re: Puncturing Pneumatic Tires
Dr. Joe J. |
Years ago I recall getting hit and having the valve stem crack which led to the tire going flat... but that's about it.
We've lost plenty of cheap (e.g. Harbor Freight) pneumatic tires over the past two years. Good luck so far on our AM pneumatics (on our air cannon, not our competition robot this year).
We're having pretty great success with them, too. Kept the split rim, just knocked the bearings out and pressed a hex-broached aluminum plug into place. Nice and cost effective, and so far it's been eating defenses alive. |
Especially with the brutal defenses of Stronghold you may be better off if you upgrade your inner tubes. At the very least have spares on hand and a procedure to swap them out. |
#8
Especially because that stuff is a mess, and flammable. When placed in a tire under pressure with air you make a nice little bomb.
#10
Whoops you are correct. I am completely wrong. Post taken down.
#11
Riveted through a tire? Yikes! How did you guys manage that?
#12
Rookie mentor?
Edit: No, I see you've been doing this a while. I haven't seen this particular thing yet, but we just started riveting seriously this year, and we opted not to do pneumatic wheels this year. |
#13
We managed to get a rivet mandrel impaled all the way through the tire and intertube. It was funny seeing a small metal dot and then pulling out a long rod. On the plus side, it's made us have spare parts ready to go to easily swap wheels.
#14
Watch your tire pressures. Too low, and when you hit the rock wall the tire (and tube) will fold and compress against the wheel edges. The result will often be 1 to 4 holes in the tube. These pinch flats are well known to offroad bicyclists and motorcyclists.
