Go to Post one wrong move and you could end up capping one of the judges. that will pretty much ruin your chance at judges' award - Mike Ciance [more]
Unread 29-02-2016, 20:04
Re: Adding a tab to driver station?
You can't modify the Driver Station. That's the program running on the bottom part of the screen. The top part (with the camera display window and the tabs with sliders and switch controls and motor power displays and variables and etc.) is the Dashboard.
If you want to follow Mark's advice, don't misunderstand it and try to right-click on the running Dashboard. You must create a Dashboard project in LabVIEW and edit it to add what you want.
