Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 29-02-2016, 21:05
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Re: pic: Lucky the Weird Dog
Originally Posted by GeeTwo View Post
I see what looks like a Raspberry pi behind the radio, probably for vision processing by the camera in the white housing (has a light ring). I'm surprised the targeting camera isn't connected directly to the pi by USB; the pi seems to have only a network connection. It looks like the RoboRIO was removed for bagging. There seems to be a battery box on the photo right side (near the SRXs), so the RIO presumably fits where you can see a fair bit of belly pan and disconnected wires (near the radio).
I see rhino tread, so presumably a sapper robot as a primary function.
The rollers seem to be designed for a simple intake/return to score low goals. I don't see how they reach outside the frame perimeter, so this may require some precision driving for boulder pickup - especially tricky as I don't see any sign of a camera at that end. I'm guessing the chassis is 26-28" wide to admit a boulder through the gap in the bumpers (here implemented in clear plastic). With the additional width of real bumpers, that may present a problem getting onto the batter.
For debugging we had the camera plugged into the pi, but the camera was unplugged when they mounted it. Since our catapult isn't done, it wasn't plugged in again because it's main purpose (auto-targeting towards the high goal) serves no purpose. I don't know much about the bumpers - I'm just a programmer. The roboRIO is under one of the plexiglass shelves. We just drive up to a boulder and it grabs it - there's a camera on the back too.
It's clearly a hardware problem.
1294 || Programmer // 2015 - Present || Board // 2017 - Present || Webmaster // 2017 - Present
