Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 28-02-2016, 20:45
flipthedog's Avatar
flipthedog flipthedog is offline
Member of Team 1389
AKA: Floris
FRC #1389 (The Body Electric)
flipthedog is an unknown quantity at this point
Puncturing Pneumatic Tires
Hello everyone,
Our team has had relatively little experience with pneumatic tires during the competition season. So I wondered how pneumatic tires hold up during competitions. Has anyone experienced flat tires in previous years? I can imagine that the current game will cause even more punctures compared to previous years.
Thank you,
Floris
Team 1389
Unread 28-02-2016, 21:09
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Puncturing Pneumatic Tires
Originally Posted by flipthedog View Post
Hello everyone,
Thank you,
Floris
Team 1389
I've used pneumatic tires many seasons and I don't remember having had a flat tire that wasn't self inflicted. I recall pinching a tube with a screw driver trying getting the tire on/off the hub. I think we popped a tire once when we used too low of pressure and the tire slipped on the hub and over taxed the valve stems that were the only thing keeping the tire from rotating further.
Dr. Joe J.
Team #88, TJ2
Unread 28-02-2016, 21:11
Joining the 900 Meme Team
FRC #0079
Years ago I recall getting hit and having the valve stem crack which led to the tire going flat... but that's about it.
Unread 29-02-2016, 01:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We've lost plenty of cheap (e.g. Harbor Freight) pneumatic tires over the past two years. Good luck so far on our AM pneumatics (on our air cannon, not our competition robot this year).
Unread 29-02-2016, 02:16
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
We're using those cheap Harbor Freight wheels. Mind detailing how yours have failed, so we can keep an eye out before it happens?
We're having pretty great success with them, too. Kept the split rim, just knocked the bearings out and pressed a hex-broached aluminum plug into place. Nice and cost effective, and so far it's been eating defenses alive.
Unread 29-02-2016, 06:51
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I think it is more of a time issue with those HF tires. The sidewalls will begin to fall apart and the rubber seems to break down after 1-2 years. When they finally let go, it is a fantastically loud noise. Two years ago we were airing up our robot carts tires and one let loose while I was sitting next to it filling it. I am by no means nimble anymore, but without knowing how or why, I was standing up before the room stopped echoing. That was at about 30 psi. We have since decided to run solid wheels and start moving away from HF wheels and tires.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 29-02-2016, 08:01
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
We didn't have any trouble with the metal, tread, or sidewalls, but we were losing inner tubes at a rate of a couple a month. All of the failures I looked at were at the seams, most commonly near the base of the filler tube. While our air cannon is a bit heavier than an FRC-legal robot (closer to 200# on 6 wheels), we never ran it at high speed or over any obstacles bigger than about a 1" transition at the edge of a sidewalk. All the ones I saw were seeping leaks, so we weren't aware of exactly when the damage occurred.
Especially with the brutal defenses of Stronghold you may be better off if you upgrade your inner tubes. At the very least have spares on hand and a procedure to swap them out.
Unread 29-02-2016, 10:30
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Originally Posted by D_Price View Post
We have had some issues with "self-puncturing" our pneumatic tires not really field or other robots puncturing them. We had a team member this year rivet through the tire but rectified that with a bottle of slime on hand in case something like this happens.
Check out rule R9. Case L in the blue box specifically outlaws tire sealant. (IIRC, this was in a team update.)
Unread 29-02-2016, 10:44
Especially because that stuff is a mess, and flammable. When placed in a tire under pressure with air you make a nice little bomb.
Andrew Basse
Unread 29-02-2016, 18:48
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Whoops you are correct. I am completely wrong. Post taken down.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 29-02-2016, 19:13
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Riveted through a tire? Yikes! How did you guys manage that?
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 29-02-2016, 23:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie mentor?
Edit: No, I see you've been doing this a while. I haven't seen this particular thing yet, but we just started riveting seriously this year, and we opted not to do pneumatic wheels this year.
Unread 29-02-2016, 23:35
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
We managed to get a rivet mandrel impaled all the way through the tire and intertube. It was funny seeing a small metal dot and then pulling out a long rod. On the plus side, it's made us have spare parts ready to go to easily swap wheels.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 01-03-2016, 06:12
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Watch your tire pressures. Too low, and when you hit the rock wall the tire (and tube) will fold and compress against the wheel edges. The result will often be 1 to 4 holes in the tube. These pinch flats are well known to offroad bicyclists and motorcyclists.
