Go to Post Aww, but I ENJOY getting all up in arms about something that's ultimately inconsequential! - Cothron Theiss [more]
Unread 01-03-2016, 07:16
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Question 2016 Clientside NetworkTables lib
Hi! I'm writing a driver station in C++ but I can't find the build for the client side network tables if we aren't running win driver. Does anyone know where the new instructions / build kit are?
Unread 01-03-2016, 07:23
restouffer's Avatar
restouffer restouffer is offline
AKA: Bob Stouffer
FRC #2539 (Krypton Cougars)
restouffer is an unknown quantity at this point
Re: 2016 Clientside NetworkTables lib
Is this what you're looking for?
https://github.com/PeterJohnson/ntcore
It has both a cmake and gradle build script, and compiles on Linux without any issues. You can select client mode with the NetworkTable::SetClientMode() call.
Unread 01-03-2016, 07:59
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
That looks like what I need (unless it turns out that I don't need jquery to run the js version ) Thanks!
Unread 01-03-2016, 08:16
restouffer's Avatar
AKA: Bob Stouffer
There is already an open source C++ / Qt driver station that you could look at to get ideas, or even to contribute to. It is multi-platform, so looking at how it handles network communication could be helpful for your project.
Unread 01-03-2016, 08:58
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Interesting, didn't know that exists (spot on, this is a Qt project I'm working on). However, that project doesn't use network tables at all (the entire dashboard is done, the only thing I'm missing is just letting the robot know whats happening on the dashboard). Thanks for the link! Definitely something to look at for the offseason.
Unread 31-03-2016, 12:29
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
I'm trying to use cmake and mingw32 to build the library, but it doesn't seem to be compiling correctly. I know it says to use the Visual Studio compiler, but I'm not planning on using Visual Studio for my project. Here are the errors I get when I run "mingw32-make" on the command line.
Unread 10-04-2016, 12:08
spat's Avatar
spat spat is offline
QDriverStation Developer
AKA: Alex Spataru
FRC #3794 (WinT)
spat is on a distinguished road
Do you have your code available on GitHub? If so, I would be glad to help you out.
As a sidenote, the QDriverStation uses a separate library (also done by me ) to handle all the client-to-robot communications, loading different communication protocols and registering joystick input. The library is also written with Qt and can be easily integrated to your project. Basically, you should only make the GUI and wire it to the library.
Links:
You can live for yourself today, or help build tomorrow for everyone
Unread 11-04-2016, 19:57
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Links:
I decided to switch to the basics and use a QTcpSocket thanks though.
