#31
Re: Pneumatic Regulators from Automation Direct
It might be good to point out to the Q&A people that the recommended regulator can be adjusted to above 60 PSI.
#32
I could have linked this thread, but I suspect the deciding parties are already aware of whats been stated here. Last edited by Holtzman : 29-02-2016 at 11:56. |
#33
Q & A has spoken with much appreciated clarity.
And that just made inspecting pneumatic systems a lot easier than it was looking over the past week!
#36
Indeed. This was a smart answer fueled by common sense on the part of the GDC. Definitely helpful to teams and volunteers alike.
#37
Once again the GDC under Frank Merrick's leadership is the most professional and most reasonable during all my years of participating in FRC.
The practical and team centric approach that FRC has been taking during the "Frank Era" of FRC is very much appreciated. What a courteous and professional response. Paul |
#38
Are there any other 'less used but legal' pneumatics components that Automation Direct sells? We have a ton of old dials, regulators, brass fittings, etc. and I'd like to know some of the parts you guys have found to be better for FRC applications. Thanks for posting this to the Q&A!
#39
Great news! We used the setup below for our robot last year and really liked it compared to massive regulators involving brass and large gauges.
![]() Regulator Pressure Gauge |
#41
Quick exhaust valves are legal for the first time this year. 3 Way exhaust valves are also legal this year for closing off sections of pneumatics Not from automation direct but McMaster and other sources carry tiny gauges (paintball sized) that are lighter. You can also get aluminum and plastic manifolds as well. |
#42
Thanks FIRST for the common sense ruling on this matter! -Mike |
#43
A quick exhaust valve is not covered by that rule, because it is not a pressure vent plug. A quick exhaust valve is a three port valve that passe air from one port to another port in one direction, but to an exhaust port in the other direction.
#45
The inline pressure regulators linked in this thread are super cool.
The literature says that they contain "a built-in relief valve to exhaust over-pressure." What determines the relief set pressure? Is it a function of the set pressure of the regulator, or is it constant? Genuinely interested (not trying for a gotcha!) in understanding how this device meets the intent of R82. |
