Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 01-03-2016, 13:32
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Re: Pneumatic Regulators from Automation Direct
Originally Posted by martin417 View Post
A quick exhaust valve is not covered by that rule, because it is not a pressure vent plug. A quick exhaust valve is a three port valve that passe air from one port to another port in one direction, but to an exhaust port in the other direction.
Sorry, I was referring to the 3-way valve that has a knob, Allen's third link. Since it only vents air from one direction, it seems there could potentially be an improper use where it would isolate a section from the vent plug which would then violate R89. Although maybe in order to get this you'd need to connect it "backwards" and it would then be venting all of the time, so it practice it couldn't really be used incorrectly. I'm just curious if anyone has found a useful application for these.
I agree that the quick exhaust valves are a nice way to vent a cylinder without needing to push air back through the solenoid.
Mentor, FRC 2052 KnightKrawler: 2008 - Present
Robot Inspector: 2013 - Present
LRI, Minnesota 10,000 Lakes Regional: 2016
