Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
Unread 03-01-2016, 03:45 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Permission denied when pushing code
OK, so based on the inputs from several on this thread, I've created a new build.xml that solves all of the permission problems and successfully deploys code from within Eclipse. I've attached it to this post.
Simply, copy the build.xml.txt file to:
c:\Users\<username>\wpilib\cpp\current\ant\build.x ml
(Make sure to substitute your user name and it should be build.xml -- for some reason the formatting is inserting what looks like a space between the x and the ml)
And the deploy will start working again. This does 2 chmods and that seems to correct the problem until Brad & Co. can find the real fix.
HTH,
Mike A.
FRC #116
