Go to Post I happen to know that there is a back-order status from Exide. Seems for some reason people are ordering this product - Mike Martus [more]
Unread 28-02-2016, 10:23
Georges's Avatar
Georges Georges is offline
FRC #5479 (Café Bot)
Georges is an unknown quantity at this point
5479 Cafe Bot's Stronghold Robot
We have high goal and low goal abilities. We can pass also pass the low bar. Unfortunately we had a really small team this year and didn't have time to build the defenses, but we can hypothetically pass the rough terrain, cheval, moat, portcullis, rock wall, sally port, and ramparts. With a bit of finesse, I believe we can also get past the drawbridge.
Thanks for looking, see you at the Saint Louis Regional!
Unread 28-02-2016, 11:22
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: 5479 Cafe Bot's Stronghold Robot
Why did you guys use surgical tubing instead of a timing belt/chain and sprocket to connnect the center intake wheels? It looks great btw!
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 28-02-2016, 13:17
Georges's Avatar
The second wheel powered by that surgical tubing was more of an after thought. Thus, we didn't have the necessary supplies/right sized belt to make it work. Adding that second wheel however increased our ability to manipulate the ball drastically.
Unread 28-02-2016, 13:33
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Looking great Cafe Bot! These guys had an awesome rookie season (8 seed alliance captain) and it looks like they'll have an even better sophomore season. Looking forward to playing with you at Chaifetz!
Robot related question - What kind of drive train are you using? I think I see some tank tread material buried in there.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 28-02-2016, 13:51
Georges's Avatar
Thanks! We ended up using the Rhino track modules.
Unread 28-02-2016, 14:39
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Looks good to. Really am interested to see where this team is in 5 years, I predict greatness. You guys look great. Also can't wait to play with you guys in STL.
Unread 28-02-2016, 17:30
Georges's Avatar
I hope so. Thank you!
Unread 28-02-2016, 18:13
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Looks good! One thing though is that it may be difficult to get over the rough terrain depending on the clearance underneath your main frame. I'm not really sure why I've seen it more on the Rhino Tracks compared to pneumatic wheels but a lot of teams it seems like are mounting there frames lower, causing them to get stuck on rough terrain.
Unread 28-02-2016, 20:58
Georges's Avatar
I'd say rough terrain is the obstacle I'm most concerned about, especially with our diamond-pattern belly pan. That said, we're planning on bringing a poly carbonate piece that we can place underneath that will barely detract from the ground clearance. We have around 1.5" of clearance, so we'll see.
Unread 01-03-2016, 21:49
squad1706's Avatar
squad1706 squad1706 is offline
You can't skeet the Skoat
AKA: Skoat
FRC #1706 (Ratchet Rockers)
Rookie Year: 2015
squad1706 is an unknown quantity at this point
Nice looking robot Cafe! I've seen a couple people in the area using tracks, but I don't think one using a Rhino. Our field is also open Saturdays to come and test your robot. It looks really good and simple. Hope to see it closer at Chaifetz in a couple days.
