Go to Post Compact gearboxes are a wonderful thing. - Cothron Theiss [more]
Unread 02-03-2016, 02:01
Re: Tasks in C++
Originally Posted by jreneew2 View Post
(which I think is really just a wrapper for a pthread).
Task is a VXWorks API wrapper around pthreads. Any reason not to use pthreads directly?
Take a look at ::std::thread. It works well, and is much more cross platform. We use it exclusively.
Unread 02-04-2016, 12:48
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Tasks in C++
Can you provide a simple example of using ::std::thread that's compatible with the roborio?
TIA,
Mike
Unread 02-04-2016, 14:34
Re: Tasks in C++
TIA,
Mike
From our code:
-- snip --
    ::frc971::wpilib::GyroSender gyro_sender;
    ::std::thread gyro_thread(::std::ref(gyro_sender));
    //  Main loop here
    // Now cleanup
    gyro_sender.Quit();
    gyro_thread.join();
-- snip --
// Handles reading the gyro over SPI and sending out angles on a queue.
// This is designed to be passed into ::std::thread's constructor so it will run
// as a separate thread.
class GyroSender {
 public:
  GyroSender();
  // For ::std::thread to call.
  // Initializes the gyro and then loops until Quit() is called taking readings.
  void operator()();
  void Quit() { run_ = false; }
 private:
  // Readings per second.
  static const int kReadingRate = 200;
  GyroInterface gyro_;
  ::std::atomic<bool> run_{true};
There are a bunch of different variants for how to create the ::std::function that ::std::thread takes for a constructor. A simpler version would be to define a void foo(){} and pass that in. You can also use ::std::bind to call arbitrary functions with arbitrary arguments.
Unread 02-04-2016, 15:42
Software Mentor
AKA: Mike Anderson
Re: Tasks in C++
From our code:
-- snip --
    //  Main loop here
    // Now cleanup
    gyro_sender.Quit();
    gyro_thread.join();
-- snip --
class GyroSender {
 public:
  GyroSender();
  void operator()();
 private:
Thanks!
Mike
