Go to Post your sense of humor - don't leave home without it. - JaneYoung [more]
Unread 02-03-2016, 09:05
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: Team Update 14 (2016)
Originally Posted by RufflesRidge View Post
That's the change to GE-16028 and GE-16178. A countersink in the plastic with a flat head screw was replaced with a counterbore with a button head cap screw.
A steel plate was used at Palmetto but does not appear to be the permanent solution.
I saw that change... I don't know anything about the exact failures seen on the CDF's at Palmetto, but I have a hard time imagining that using a BHCS in a counterbore vs a flat head screw in a countersink is significant enough to prevent CDF's from breaking consistently (as the unmodified ones did at Palmetto).
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
