Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 02-03-2016, 10:32
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Can you set the position on a CAN JAG to something other than 0?
With the Talon SRX there is a "set sensor position" block I can call but the JAG doesn't seem to have an equivalent. I know you can reset a position by calling the enable block but the "reset" we do doesn't happen at position 0 so we need to be able to set the position to an arbitrary value. Anyone know how to do this?
