Go to Post That wheel appears to have been forged deep within the fires of Mount Awesome. - viking1902 [more]
  #46   Spotlight this post!
Unread 01-03-2016, 13:32
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Re: Pneumatic Regulators from Automation Direct
Originally Posted by martin417 View Post
A quick exhaust valve is not covered by that rule, because it is not a pressure vent plug. A quick exhaust valve is a three port valve that passe air from one port to another port in one direction, but to an exhaust port in the other direction.
Sorry, I was referring to the 3-way valve that has a knob, Allen's third link. Since it only vents air from one direction, it seems there could potentially be an improper use where it would isolate a section from the vent plug which would then violate R89. Although maybe in order to get this you'd need to connect it "backwards" and it would then be venting all of the time, so it practice it couldn't really be used incorrectly. I'm just curious if anyone has found a useful application for these.
I agree that the quick exhaust valves are a nice way to vent a cylinder without needing to push air back through the solenoid.
Mentor, FRC 2052 KnightKrawler: 2008 - Present
Robot Inspector: 2013 - Present
LRI, Minnesota 10,000 Lakes Regional: 2016
  #47   Spotlight this post!
Unread 01-03-2016, 13:33
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by Nate Laverdure View Post
The inline pressure regulators linked in this thread are super cool.
The literature says that they contain "a built-in relief valve to exhaust over-pressure." What determines the relief set pressure? Is it a function of the set pressure of the regulator, or is it constant?
Genuinely interested (not trying for a gotcha!) in understanding how this device meets the intent of R82.
It means it's a relieving valve, if you were to set it to 60psi and one of your cylinders that is extended is then compressed by an external force that would increase the system pressure downstream of the regulator to > 60psi this regulator will exhaust pressure maintaining the system at 60psi downstream from it.
  #48   Spotlight this post!
Unread 01-03-2016, 13:36
Engineering Coach
The 3 way exhaust valves are useful for isolating a system during maintenance etc. They aren't very useful during a match in my opinion but I could be wrong. You could have a 3 way exhaust valve in front of the solenoids you use to fire a pneumatic catapult. When turned closed the air going to the catapult would be exhausted and the rest of the system would still function but the catapult would be disabled.
  #49   Spotlight this post!
Unread 01-03-2016, 13:41
President, VEX Robotics, Inc.
The relief feature is based on the set pressure so it completely meets the definition of the rule. If you take a large pneumatic cylinder downstream that is extended and then manually push it back, if the regulator did not exhaust then the regulated pressure will go beyond set pressure.
The exhaust feature is required to be legal. That is why many of us already thought the regulator was legal. This q&a answer confirms it is legal.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #50   Spotlight this post!
Unread 01-03-2016, 13:42
Engineering Coach
A quick exhaust valve is however a check valve so it must be used in a way that the system is able to satisfy R89.
R89 G. Check valves, provided that the requirements of R89 are still met.
Another useful item that AutomationDirect sales that not enough teams use is 1/4" push connect plugs.
Very useful for closing off solenoids and things. Much easier then using a T fitting and a loop of tube like some teams do.
  #51   Spotlight this post!
Unread 01-03-2016, 14:06
Nate Laverdure's Avatar
FRC #2363
Yes, I understand that's the desired function of the valve. With only the Nitra docs as a resource, I couldn't convince myself that the valve actually functions that way. (One concern I had is that the Nitra docs don't use the ISO symbol for a relieving regulator, but the Norgen docs do.) Glad to hear that, based on your experience, the device operates the same way that a "pressure relieving regulator" is generally understood to work.
What a relief, huh?
  #52   Spotlight this post!
Unread 01-03-2016, 14:38
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
I'm not sure you are thinking of the correct valve. I don't see a way to use a quick exhaust to isolate anything. The advantage of the quick exhaust is to allow the air to vent freely in one direction so it doesn't have to go all the way back to, and then through, the valve. That way a cylinder can act much more quickly. If you were using a cylinder as a pusher or punch for the ball, you could use a quick exhaust on the rod side of the cylinder. That way, when you pressurize the retract (rod side) port, the cylinder would retract, and when you pressurize the extend side, the cylinder would extend, but you would not have to force the air from the rod side all the way back through the tubing to the control valve, instead it could exhaust right there at the cylinder.
Edit: here is a good example.
Former Mentor Team 1771
Former mentor Team 4509
  #53   Spotlight this post!
Unread 01-03-2016, 14:39
martin417's Avatar
AKA: Martin Wilson
It's only a check valve if you plug the exhaust port. You could also plug any other port on the system and violate the rules by trapping air.
  #54   Spotlight this post!
Unread 01-03-2016, 14:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
A easy way to tell if a regulator is self relieving (FRC Legal) is on a system with no leaks, a self relieving regulator will decrease the low side pressure when backed off. A non relieving regulator will not.
We used the little AD regulators and quick exhaust valves on an off season project. Cool stuff.
  #55   Spotlight this post!
Unread 01-03-2016, 18:52
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
What a relief, huh?
The nitra regulator is actually a metal works regulator (or at least marketed as metal works). I have used the metal works variety since 2014,. they are for sure relieving. I used them on the 3309 's 2014 robot in the intake to relieve air from impacts in addition to running the intake at lower pressure.
the metal works documents are a lot better with their symbols but not perfect:
http://www.metalwork.org/pdf/04_NPT_...A_20_09_13.pdf
I have not noticed a difference from the nitra and metal work samples I have now.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
  #56   Spotlight this post!
Unread 01-03-2016, 23:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
What a relief, huh?
B'dmp'bmp'psssh.
  #57   Spotlight this post!
Unread 01-03-2016, 23:40
Engineering Coach
I'm not talking about a quick exhaust valve in this comment, I'm talking about a 3-way exhausting valve, part H. of rule R77. Such as this
R77 H. Shutoff valves which relieve downstream pressure to atmosphere when closed (may also be
known as 3-way or 3-way exhausting valves).
It's a check valve no mater how you plumb it, it's only legal to use it if you don't plug the exhaust port. The rule that allows quick exhaust valves like this to be used is
R77 G. Check valves, provided that the requirements of R89 are still met.
The quick exhaust mechanism is inherently a check valve.
Do you think a different part of R77 applies to quick exhaust valves?
  #58   Spotlight this post!
Unread 02-03-2016, 10:02
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
... and as a friendly reminder - look in your KOP for the Automation Direct Voucher instructions ( or go here).
It's valid through Championships (April 30th, actually).
You can order anything you want from Automation Direct's 20,000 part inventory using the $30 voucher. Pneumatics, crimp lugs, tools, safety glasses, sensors/encoders, pulleys/belts/shaft couplers, etc.
And since most of the pneumatic parts mentioned are under $30, well ... you do the math.
Shipping is a flat $6 (not included in the voucher), but if you purchase $49 worth of stuff beyond the Voucher, Shipping s FREE via Fed-ex 2-day. We have Canadian and California teams tell us they get stuff faster from ADC than if they order from local suppliers!
We are pushing this because the more teams use it, the more we will be able to influence next years contribution to FIRST ...
So consider this a gentle nudge to get the word out ... Thanks!
  #59   Spotlight this post!
Unread 02-03-2016, 10:26
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I can never get this voucher to work for my team. I think because there is some wacky bug when I login as my company Automation Direct account, it doesn't accept the voucher or something. Is there a clear process for how to use the voucher and if you can login with an existing Automation Direct account? Or should a setup a SEPARATE AD account to use the voucher?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
  #60   Spotlight this post!
Unread 02-03-2016, 10:40
Chris,
I had to use a separate, personal account and it worked fine.
Paul
