Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Unread 02-03-2016, 13:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Gearbox Design for an FTC Robot
Originally Posted by Cothron Theiss View Post
Ah, I see. Sorry, I posted before checking the FTC rules. But I'm sure there is a motor/gearing option that gives you the speed and torque you want with a simpler solution, and less motors.
The motors available to FTC are:
NeverRest 20/40/60 (all the same motor with a different gearbox attached)
Tetrix 12v (almost complete garbage)
Matrix (also pretty bad, but I don't have a ton of experience with them)
VEX 393 (completely underpowered here)
A variety of servos (not what we're looking for)
If they're 40s in there, they might be able to lift with 1 or 2 60s depending on their robot's weight, but that also might be slower than they want. It's a pretty limited motor pool for FTC, especially compared to FRC. I don't doubt they might be able to crunch some numbers and come up with a "better" solution, but we don't know what numbers they've already run and exactly how fast they need to pull up how much weight.
As for improving it: While this might be fine, generally I prefer to place the motors as few stages away from the shaft they're driving as possible. If you can, I'd second the motion to drive the winch gear with each of the motors directly next to it instead of driving them through each other. This is generally good practice for gearbox design.
It looks like you might have small bearings in the gearbox plate-- this is good, keep it up. For something that gets a lot of stress, you want to avoid cantilevered shafts, so supporting both sides is good.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
