Re: Extreme curve?
You might want to implement a PID control for the right/left side of the drive. Of course, you will need encoders for this on each side to provide feedback, but once they are plugged into the Talons, you can go about programming the wheels to set speed (or position or whatever, there are a lot of options, you'll probably use speed) instead of percent voltage.
This will help you control the actual output from the motors rather than voltages.
This is a way to fix the issue programmatically. If you need help PM me, and I can help you (our team uses LabVIEW, but implementation in Java/C++ shouldn't be too different, right?).
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
