Go to Post Every year I develop new connections and greater friendships with FIRSTers - and every year I am surprised to find just how many amazing people there are here. - MysterE [more]
Unread 03-02-2016, 07:08 PM
anusha2617's Avatar
anusha2617 anusha2617 is offline
FRC #0178
anusha2617 is an unknown quantity at this point
FRC Driver Station: No Robot Code
Every time we compile our code from Eclipse while connected to a RoboRio, it says "Build Successful." But when we open up the Driver Station to Enable the code, it gives us a warning that we don't have robot code.
Name:	Build Successful.png
ID:	20253  Click image for larger version
Name:	No Robot Code.png
Unread 03-02-2016, 08:10 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: FRC Driver Station: No Robot Code
You're probably erroring out. You can check this by hitting the gear above the ds console and clicking "prints" than redeploying code
Unread 03-28-2016, 04:19 PM
ARaine ARaine is offline
FRC #2834
ARaine is an unknown quantity at this point
If there is no error message just reboot the roboRIO. Sometimes the robot code does not start even though the code should run fine. I found this when I made one minor change (hardly code breaking) and the code did not start or provide an error message.
