Go to Post In conclusion we will have a spaghetti game - Darkseer54 [more]
Unread 02-04-2003, 08:34
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Red face Basic Run Error
I was wondering maybe someone can help me out here! At our regional we were trying to load our Autonomous program onto the bot. It compiled right and everything but our IFI kept on giving us "Basic Run Error" that and for some reason It did not except the 2003 Default Code!! We had Tom form IFI stumped, I think he is still trying to figure it out! My teams programmer is going to get the latest version of the compiler and see if that works! It makes no sense!!! It compiled yet we got "Basic Run Error"..... has anyone had a similar problem?? Maybe it is something with our IFI. Our Bot has like Multiple Personalities.... hilarious I tell you!
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 02-04-2003, 09:12
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Doesn't this typically happen if the serin statement is malconformed? Perhaps a sensor was added to the autonomous mode and the c_sensorX constant or the serin itself wasn't modified? This happenes sometimes in the "heat of the competition" where things are easy to forget.
It would help to have the code available to trace down the problem, though.
Unread 02-04-2003, 09:18
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
01001000001000101000101000001001001001000101001001 0001001001001000100100101010
Ok just kidding, But to try and help with this, Is it possible that you can send me either a cut and paste or the file itself. Also when the you get the run error, doesn't it go back to the code and highlight the code where the error is? I pulled out what hair I have left on an error I had and all it was was a simple little space in the wrong place.
Unread 02-04-2003, 09:53
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Try resetting it. It might fix the problem. Sometimes after we program that light comes on, but it goes away after we reset it.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 02-04-2003, 10:42
Re: Basic Run Error
Because it doesn't work with the default code, it is probably a hardware problem, and not a software problem, so posting your code (as others have suggested) probably won't help. That is assuming that you didn't accidentally modify the default code and save it as the same file.
Did Tom give you a replacement controller to try?
Unread 02-04-2003, 14:45
tonyargote's Avatar
tonyargote tonyargote is offline
#0059 (RamTech 59)
tonyargote is an unknown quantity at this point
Send a message via AIM to tonyargote Send a message via Yahoo to tonyargote
HELLO Adriana!!
(Did you guys have fun up there? I saw the webcast. Congrats on making it to semifinals.)
Ok about the program. Did you try to load the Program from FIRST website, or the 2003 defualt code that comes with BASIC Stamp?
(Tony became a programmer this season, as well as a webmaster, and driver. Pretty Freaky huh?)
CYA Dude!
TArgote
Driver, Programmer, Webmaster
www.RamTech59.com
UCF: Ranked 13th (2nd Highest QP's in the Nation! (349))
Championship: Ranked 12 out of 73 teams in Archimedes Division, Quater finalist allied with 1108 (GO 1108!) & 868 ( GO 868!)
Unread 02-04-2003, 15:01
David.Cook's Avatar
David.Cook David.Cook is offline
#0384 (Sparky)
David.Cook is an unknown quantity at this point
Send a message via Yahoo to David.Cook
YES! and no.
" and for some reason It did not except the 2003 Default Code!! "
Yes, I saw exactly this problem.
I had this same problem. I had been using my personal laptop to work on code, and we had another older laptop that belongs to the school on which we also were working on code. Originally, I put the 1.33 version of the Basic Stamp editor on my personal laptop. I was able to load code, we worked on some different things - no problem.
Then we decided to figure out the multi-bank programming. At this point I upgraded to the 2.0 Basic Stamp editor and worked on code. The first time I loaded it - Basic Run Error! After hours of failure I decided to try something... I loaded the known working single bank code - Basic Run Error! In short, I could no longer load and run code from my own laptop. My laptop was running Win 2000, SP 3. I contacted Parallax and they suggested uninstalling both versions and reinstalling only one, etc, etc. I tried many things with no success (as a software engineer I was totally frustrated at the lack of a solution).
No, I don't know how to fix it.
In the end, after many hours of investigation, I decided to drop it, and we did all further work on the older laptop (which runs Win 98). I was never able to get my laptop to properly load working code into the RC anymore.
Sorry for the lack of help. I guess you could try uninstalling and reinstalling, but I am afraid that it is not lilkely to help. My best advice is try using a different computer to load the code.
Good luck!
Be unrestrained as the wind...
Unread 02-04-2003, 15:50
If you somehow ended up with an older Robot Controller in your bot, then you need to hit the RC reset after you download new code.
Other than that - I would stick with the older compiler - they dont call the new one a 'Beta release' for nothing :c)
those of us who have been writing SW for a while know from experiece that "Beta" means: Beta not use it!
Unread 02-04-2003, 16:59
Matt Reiland's Avatar
'The' drive behind the drive
Doubt it is the problem but we actually have 2 Dell laptops that when connected to the Program port, will not allow the RC to stay in run mode. Something in the implementation of the Dell serial port on those laptops bogs the RC down, unplug the laptop and it fires right up no problems.
Unread 02-04-2003, 17:04
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
This is actually due to the fact that your laptops are holding the DTR pin of the serial port in the wrong state. The DTR on the serial port is connected to the reset line of the Stamp, so basically you're holding the Stamp in reset whenever the laptop is plugged in.
To the original poster: did the Basic Run Error problem happen even when the laptop wasn't plugged in to the programming port?
Unread 02-04-2003, 22:43
Dusan Dusan is offline
#0548 (Robostangs)
Dusan is an unknown quantity at this point
Basic Run Error
If you look it up in the Basic Stamp manual, you'll find that the Basic Run Error is due to the Serrin Outputs.
Try to see if your inputs match the outputs and visa versa. Also make sure all your constats are enabled for the sensors, if you're using analog sensors.
Double check the SerrinOut and the constants in the Initialization ... that should solve your problem ... hope it helped
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Init Error yan184 Programming 5 14-12-2002 13:10
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
BASIC error punarhero Programming 4 16-02-2002 23:21
BASIC Stamp Error mpatterson Programming 4 22-01-2002 12:08
