Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
Unread 02-03-2016, 22:00
Broncobot_kae22 Broncobot_kae22 is offline
AKA: Scott
FRC #5201 (Bronco Bots)
Broncobot_kae22 is an unknown quantity at this point
Pneumatic assistance
We need help. We have turned everywhere and no one has been able to help us. The compressor comes on but none of the solenoids are working. We have had the code checked out and that is fine. How do we test it? We bought a new PCM and put it in, it has changed nothing. Thanks!
Unread 02-03-2016, 22:11
Brian662 Brian662 is offline
Brian662 is an unknown quantity at this point
Re: Pneumatic assistance
Are you specifying the PCM ID in the code? Our team had a similar problem but we weren't specifying a PCM ID.
Unread 02-03-2016, 22:15
Kyle Heaton's Avatar
Kyle Heaton Kyle Heaton is offline
I like volunteering.
Kyle Heaton will become famous soon enough
Is your PCM connected with CAN wires properly?
Are you correctly opening and setting values for the solenoids?
Are your solenoids single or double, as that will change what values you need to send to them for them to trigger.
Software Lead Student 2014-2015
Student Technical Lead 2015-2016
Tippecanoe District Winner - Perry Meridian District Winner - District Champs Semifinalists
Kokomo District Quarterfinalists - Dean's List Indiana District Finalist
Arkansas Regional Quarterfinalists - Boilermaker Regional Quarterfinalists
Unread 02-03-2016, 22:30
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Is your PCM set to the same voltage that your solenoids are?
461 Westside Boiler Invasion
45 Technokats
Unread 03-03-2016, 00:37
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Do your solenoids work if you trigger them manually?
Mentor http://www.teamtitanium.org/
Unread 03-03-2016, 06:35
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Are you powering the working part of the system with over 30 psi?
Some valves need this to work.
Are you giving the valves the correct voltage?
There are 12v and 24v valves.
Are you sending pressure to one or both sides of the cylinder?
Try testing with tubing connected to both extend and retract sides of the cylinder.
Install manual dump valves and use these to verify that air is getting to the valve ports.
There is an input and an output side to most valves. Find the valve part number and look up the part to verify.
You can always call that valve's distributor, for info about the valve.
Dave
Unread 03-03-2016, 09:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
A complete set of pictures of how you're wired and plumbed would help.
I suggest adding a pressure valve close to the inlet of a valve to ensure that you have pilot pressure. Due to some strange plumbing, on our first iteration, once we made the initial switch from initial to "gameplay" configuration, we were dumping air so fast that we lost pilot pressure.
Watch all of your diagnostic lights (most solenoid valves have these) to see if the solenoids are getting the signal; this will tell you if your problem is on the electrical side or pneumatic side.
Some solenoid valves have polarized inputs. Reverse voltage will usually not damage them, but they won't function. Check this out. (IIRC, we have at least one solenoid valve which, if wired backwards, will light the LED but not actuate the valve; seems really strange, but there it is.)
Try the manual switch buttons/levers (most solenoid valves have these). This will also help you figure out whether you have an electrical or pneumatic side problem. (If things work with the manual, it's almost certainly electrical; if they don't, it's almost certainly pneumatic.)
Unread 03-03-2016, 09:31
Divide the problem into code vs electrical/pneumatic.
Correct code: The PCM individual solenoid LEDs light up red when your code functions, and the lights are properly matched, e.g., one side of a double solenoid is off while the opposing side is on, then your code is operating properly. Get this working first.
Unread 09-03-2016, 11:17
JOomkes JOomkes is offline
FRC #4967
JOomkes is an unknown quantity at this point
You may want to check that you are not overloading the PCM. If you are using too many valves at 12 volts with to high an amperage, you can replace them with a 24 volt and a lower amperage that will do the same thing but not overload the PCM. Running on either 12 or 24 volts you need to also make sure that all of the solenoids are that same voltage. We had a problem with this on our robot.
