Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Unread 02-03-2016, 23:04
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: Spike relays not working
Originally Posted by cbale2000 View Post
Check the fuse on the spike? Make sure it isn't bad.
If I'm not mistaken, the relay should still follow code if the fuse is bad (I.E. you will hear the relay click, and will see a change in light code). Whatever accessory you are trying to manipulate will not work, however.
I'm going to agree with Mr. Tanguay and Peyton. That sounds like a bad cable or a bad unit. Consider swapping one of them (try one at a time, this can help you isolate which piece of the puzzle was faulty, and can help you identify what to throw away!).
J Wallace IV
Truck Town Thunder
Just a college student now.
