Re: pic: Team Titanium 1986 - 2016 Robot
Like the Wheels, what are they?
8" pneumatic mountain board tires on AndyMark pneumatic hubs.
I like the autonomous modes. Our robot can do 5 defenses in autonomous (All but C and A). Our robot can do A defenses, just not in auto. Your robot seems to do the A defenses with no problems in auto so that's great. So the catapult has a multi stage stop mechanism. Reminds me a lot of 118 in its design. Great robot and I wouldn't be surprised to see you with blue banners. Good luck at your events. Climb mechanism was pretty cool. Ever have issues with tape measure falling over? Thanks.
The tapes can buckle if the driver is overzealous, but they are stable with normal movement. We are aided by the rule against contact in the final 20 seconds.
This. Is. Genius.
Great bot, one of the best I have seen so far. Again, Team 1986 impresses.
Question: how did you vary the distance on the catapult to shoot at different angles? |
#7
As an example you can make out a set of paired cylinders in the bottom right of this 2014 pic. One cylinder rod points up while the other one points down. ![]() Our other thread had a similar question and answer. http://www.chiefdelphi.com/forums/sh...2&postcount=16 |
#8
Great bot as always guys. Your team always puts together some of my favourite robots each season. Just saw that we'll be seeing each other at Smoky Mountain Regional. See ya in Week 5!
#9
What kind of rope are you using for your winch/hanger?
I always love the designs 1986 puts out. Thanks for the inspiration! |
#10
It is braided spectra spearfishing line. 550 lb capacity and only .060 dia. The brand name is "SPEARIT", available from your local spearfishing store.
#11
We are using a lot of spectra on our robot this year, mostly 1/8" diameter. It's amazing how many uses it has once you figure out how to splice and use it properly. Probably my favorite building material at the moment.
#12
How did y'all drive those tape measures? And which ones did you use? (I don't need to tell you this, but that machine will dominate wherever it competes!)
#13
Awesome robot as usual Titanium! It was great to see it in person at the scrimmage and we are looking forward to watching you in action next week at the KC Regional.
It never ceases to amaze me how 1986 finds innovative ways to solve complex problems. Also, having seen this machine up close, I was really impressed with how you fit everything in such a compact bot. That is a feat in and of itself. Best of luck to you! |
#14
Creative programmer on our team has named the four height buttons on our console from lowest to highest: dungeon, stocks, gallows and Rapunzel. Going with the castle theme... |
