Go to Post While many teams like to go fast, only a select few do it well. - Al Skierkiewicz [more]
Unread 16-03-2015, 21:05
gbruck33013 gbruck33013 is offline
FRC #4655
gbruck33013 is an unknown quantity at this point
Re: Team 1515 Presents MorScout
Thanks for making your scouting application available. I down loaded and installed node.js. After loading node.js, I opened the command window by selecting node.js from the start menu. At the print I type node --harmony userManger and it is not working.
Here is what is reported when I try the node comand:
node --harmony userManager
SyntaxError: Unexpected identifier
at Object.exports.createScript (vm.js:44:10)
at REPLServer.defaultEval (repl.js:117:23)
at bound (domain.js:254:14)
at REPLServer.runBound [as eval] (domain.js:267:12)
at REPLServer.<anonymous> (repl.js:279:12)
at REPLServer.emit (events.js:107:17)
at REPLServer.Interface._onLine (readline.js:214:10)
at REPLServer.Interface._line (readline.js:553:8)
at REPLServer.Interface._ttyWrite (readline.js:830:14)
at ReadStream.onkeypress (readline.js:109:10)
Any ideas as to what I may have done incorrectly?
Unread 18-03-2015, 16:39
legomann97 legomann97 is offline
FRC #2486
legomann97 is an unknown quantity at this point
Whenever I try putting in "sh$ node --harmony userManager", the command prompt says that 'sh$' is not recognized as a batch file or operable program... Can you help me please?
Unread 18-03-2015, 17:31
FRC #2486
Ok, I fixed the previous error, but now I can't start the server. It gives me the IP Address, but then it throws the following error:
events.js:85
throw er; //Unhandled 'error' event
Error: listen EADDRINUSE
at exports._errnoException (util.js:746:11)
at Server._listen2 (net.js:1129:14)
at listen (net.js:1155:10)
at net.js:1253:9
at dns.js:85:18
at process._tickCallback (node.js:355:11)
at Function.Module.runMain (module.js:503:11)
at startup (node.js:129:16)
at node.js:814:3
I have no clue what is going wrong here, so any help would be appreciated!
Unread 18-03-2015, 17:44
FRC #2486
I also can't submit any feedback. I'm not logged in, but i think it should be allowed even if you aren't logged in.
Unread 24-03-2015, 17:36
chiefwebmaster's Avatar
chiefwebmaster chiefwebmaster is offline
FRC #3169
chiefwebmaster is an unknown quantity at this point
events.js:85
at net.js:1253:9
at dns.js:85:18
at node.js:814:3
I am getting the same error. Looking forward to getting some help.
Edit: I just got an email back that fixes this error. All you have to do is change
node --harmony server
to
node --harmony server 8081
This changes the port code and fixed our error.
Unread 03-03-2016, 09:29
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
This might be a strange question, but how can we use this without WiFi at events?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
