Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 02-03-2016, 12:36
Physics Quiz 12
This is something I haven't done before in these quizzes. I'm going to post a question from a textbook (I modified the wording slightly).
The problem looks complicated, but if you carefully apply the few simple rules of free body diagrams the answer is simple algebra.
The problem is about forces and torques, an area especially applicable to FRC.
High school students only, please.
Unread 02-03-2016, 14:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Physics Quiz 12
Nice one.
Not that I'm going to answer, but is the 0.5m/s speed measured along the rail, or just horizontal or vertical component?
Unread 02-03-2016, 14:28
Re: Physics Quiz 12
Originally Posted by GeeTwo View Post
Nice one.
Yes
Unread 02-03-2016, 22:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Physics Quiz 12
Nice question.
Related question: I couldn't find any of those frictionless rollers at McMaster, got a source for them?
Unread 03-03-2016, 09:30
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Physics Quiz 12
I think I saw some last time I was at Theory Depot.
Unread 03-03-2016, 16:53
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
Re: Physics Quiz 12
I attempted this yesterday, and I'm still not sure if I'm doing this correctly. I feel like I'm missing some step, but what I've done so far is below.
Assumptions / notes for part 1:
- The only thing that matters is the gravity component parallel to the rail, and the tension force parallel to the rail.
- The cart moves as a single body along the rail (it doesn't matter which part of the cart the rope is attached to)
- The 0.5 m/s is irrelevant, what does matter is that it's moving at a constant velocity (i.e. acceleration = net force = 0)
Part 1:
T = 5448 N
I'll post a picture of my working when I get a chance, but basically what I had was:
F_gravity = F_tension
m*g*sin(20deg) = T cos(12deg)
(All are the component parallel to the 20deg rail)
Assumptions / notes for part 2:
- The angle of the rope is less than the angle of the rail, so the cart is being pulled "into" the rail.
- This creates torque around point G and the cart is basically being twisted.
Part 2:
I'm not entirely sure how to do the calculations on this, but I'm guessing it results in rollers A and C being pulled "down" and B and D pulled "up."
Last edited by Rachel Lim : 04-03-2016 at 13:43. Reason: Not sure where I thought there was a ramp...
Unread 03-03-2016, 17:48
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Physics Quiz 12
A hint for Rachel (and all),
For part 2, both the weight of the cart and the tension in the cable produce torques about any center of rotation convenient to calculating either of the roller forces.
Unread 03-03-2016, 18:11
Re: Physics Quiz 12
- The only thing that matters is the gravity component parallel to the ramp, and the tension force parallel to the ramp.
This is the first necessary insight.
- The cart moves as a single body along the ramp (it doesn't matter which part of the ramp the rope is attached to)
I think you meant the rail, the cable, and the bucket?
Correct. This is the second necessary insight.
The 0.5 m/s was indeed a red herring. Part of solving physics problems is eliminating irrelevant information.
Part 1:
T = 5448 N
Correct!
Unread 04-03-2016, 11:48
Re: Physics Quiz 12
Part 2:
I'm not entirely sure how to do the calculations on this...
Do you want to continue working on it by yourself? Or shall I invite high-school teachers to chime in?
Unread 04-03-2016, 14:19
Team Role: Student
Re: Physics Quiz 12
Sorry, I had homework...what I have is below, but I welcome all other input.
I think I fixed the ramp / rail / cart thing in my previous post (I should really proofread more carefully).
Part 2:
I calculated the torque produced by gravity around point G, and the torque from tension around point E. I then subtracted the two values to find the overall torque. For example, for point A:
torque_gravity = (m*g)(distance_AG)(angle_AG to vertical)
= 15582*1.2*sin(20deg)
= 6395
torque_tension = (T)(distance_AE)(angle AE to ET)
= 5448*1.7*sin(140deg)
= 5953
So the overall torque around point A is 442 N*m in the counterclockwise direction.
With this method, I got that all four rollers have torque in the counterclockwise direction, of magnitudes 442, 402, 24082, and 24092 Nm (A, B, C, D).
This is where I get stuck again, because I don't know how this correlates to figuring out which rollers make contact--is it the magnitude of the torque? The difference in the respective pairs?
Unread 04-03-2016, 15:10
Re: Physics Quiz 12
Part 2:
You have to pick one point, and sum all the external torques around that one point, and set that sum equal to zero. Then solve.
If you pick the point carefully, the equation will have only one variable, so you can solve for it.
= 6395
= 5953
Gravity and cable tension are not the only forces producing torques around point A.
What other external force(s) is(are) acting on the bucket+rollers+ore free body?
Mentors, Teachers, etc: Rachel is a very bright student. Let's give her (and any other students who may be following the thread) a chance to solve the problem.
Unread 09-03-2016, 09:29
Re: Physics Quiz 12
To close out this thread, I'd like to invite any college students to jump in here and show how to solve part (b).
Unread 15-03-2016, 11:42
Re: Physics Quiz 12
How about high-school physics teachers?
Unread 15-03-2016, 14:28
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Re: Physics Quiz 12
http://i.imgur.com/jYv6saa.jpg?1
http://i.imgur.com/SdCGmYc.jpg?1
I know this is pretty messy and the progress is kind of scattered, but here's my full FBD of the cart. Wheels A and D are contacting the rail: 16423 N at point A and 632 N at point D.
One of the things I think Rachel missed (though her work is very impressive) is the torque arm for the tension is 1.0 meter, which is found by extending the force vector backwards until a perpendicular line crosses through point A. So the torques are as follows:
torque_gravity around A = 6396 N*m
torque_tension around A = -5448 N*m
torque_(either C or D) = -948 N*m
The final point of contact must be point D so the force on the rail is downward.
Then its just a matter of finding the force on point A by setting the "vertical" forces equal to zero.
Sorry about the messy work.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 15-03-2016, 16:30
Re: Physics Quiz 12
If D is contacting the rail then the force on the rail at D must be upward (perpendicular to the rail)
... and the force on the D roller is downward (perpendicular to the rail)
Double-check that 632N number.
