Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 03-03-2016, 00:58
parkerthenoob parkerthenoob is offline
FRC #4495
parkerthenoob is an unknown quantity at this point
Connection to Radio but not RoboRIO
Our competition is tomorrow, and our programmer dropped out so I'm doing a little last-minute troubleshooting.
Our Driver Station connects wirelessly to the Robot Radio, but does not connect to the RoboRIO. We've re-configured the radio and updated the RoboRIO multiple times. We've switched Enet cables. The computer can't ping the team's network, yet we can connect to our team's network. We've enabled DHCP, and turned off Firewall and Antivirus software.
We know it's not a communication issue between the Radio and the RoboRIO, because we have another computer that connects to both wirelessly. Unfortunately, this computer cannot currently run code.
We feel like we've tried just about every approach to fixing this that we can find. Any ideas would be greatly appreciated.
Unread 03-03-2016, 02:10
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Eryl2000 is an unknown quantity at this point
Re: Connection to Radio but not RoboRIO
We had a similar issue a while back. It seems for us that the bridge was taking so long to boot up that the RoboRIO stopped looking for a bridge to connect to. We "solved" this by waiting for the radio's green connected light to turn on, and then pressing the reset button on the RoboRIO. We have looked into a better fix for this, but so far we have not found one. I hope this helps.
Eryl
Unread 03-03-2016, 10:02
I've yet to actually see this, but the recommendation is to swap the port at the radio that connects to the roboRIO. The expectation is that this issue will not happen if it is connected to the port next to the power connector. But swapping to the other port to see if it changes symptoms is also in order.
Greg McKaskle
Unread 03-03-2016, 11:36
FRC #4495
Eryl
Thank you! We will try that.
Unread 03-03-2016, 11:37
FRC #4495
Greg McKaskle
Ok, thanks. We will try swapping ports.
Unread 03-03-2016, 14:54
FRC #4495
As it turned out, what ended up working was plugging into the roborio via USB, waiting for it to connect to the network and Driver Station, and unplugging the USB cable. It finally connected wirelessly. Thanks for the help.
