Go to Post HOLY MOLY CANOLI THIS LOOKS LEGIT - MasterEric [more]
Unread 03-03-2016, 12:23
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
Removing tread from colson wheels
Does anyone know how to separate the hubs from the tread in colson wheels?
I'm looking at a project where I need a 3in minimum bore in the wheel, and would like to use colson tread with a custom hub.
Could I alternatively find just the tread some where, or could I just drill out the wheel?
Unread 03-03-2016, 12:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Removing tread from colson wheels
The Vex Colson page says they have "integrated hubs". I think your best bet would be to bore out the hub rather than to try to separate them. Though if you need a 3" bore, you may be boring out part of the rubber material even on most of the 4" wheels. That could get tricky.
Unread 03-03-2016, 12:40
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
You aren't going to be able to effectively remove the hub, boring it out is the only option if you really need the colson tread.
As an alternative to the colson tread, vexpro sells "traction tires" for their traction wheels. These offer similartraction and non marking characteristics and allow you to relatively easily design and make your own hubs (assuming you have a CNC or the wheels are loaded low enough to 3d print).
http://www.vexrobotics.com/vexpro/mo...on-wheels.html
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 03-03-2016, 12:41
Chris is me's Avatar
AKA: Pinecone
The Colson rubber is molded onto the wheel hub at manufacturing time. It doesn't really detach and it would be difficult to attach it to a different core without the tread slipping on the core.
For a wheel you need such a large bore for, your best best is to use fabric backed tread material like roughtop or wedgetop. If you want to use smooth rubber that is vaguely Colson like, I recall somewhere on McMaster you can find fabric backed polyurethane ideal for attaching to wheels.
You could try drilling out a larger Colson wheel, but 3" is a bit extreme.
Unread 03-03-2016, 14:20
krakow1444 krakow1444 is offline
FRC #1444
krakow1444 is an unknown quantity at this point
On my team we have lathed down the the wheels, it is very tedious work. But another option is if you gently vise up the wheel, you would be able to take a 3 inch hole saw and saw it out. In opinion the hole saw would be a lot sloppier than the lathing.
Unread 03-03-2016, 15:07
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Putting a big hole in a Colson has been done by at least 2 teams that I know of, the first example being the CIM in wheel swerve module. My understanding is that this was done on the lathe with a large drill bit, and then a boring bar.
Unread 03-03-2016, 15:18
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, what about a hole saw in the drill bit chuck of the lathe?
GitHub
Unread 03-03-2016, 15:30
Jared's Avatar
Jared Jared is offline
You can bore out the large colson wheels, but they will have little voids like in this picture
Unread 03-03-2016, 15:42
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Could work with a sharp saw, relatively slow speed, and frequent stops to clear. And patience.
edit: See picture in the post above. Boring bar is better than hole saw because it gives the removed material a path out.
Richard Wallace
since 2003
Unread 03-03-2016, 16:19
Jared's Avatar
Colson wheels machine really well, so you can bore them out really quickly - probably faster than if you were to use a hole saw. Freshly sharpened HSS tools will work better that carbide in my experience, but both will work.
