Go to Post Omni wheels are cool... but mecanum wheels are COOL!! - dtengineering [more]
Unread 03-03-2016, 08:12
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
FRC Dashboard 2016: flashes, then goes gray at driver station startup
We are using the provided LabView tank drive template. Please help!
We have rebooted the Classmate 14, win 7. It was working perfectly Monday.
Unread 03-03-2016, 09:58
Re: FRC Dashboard 2016: flashes, then goes gray at driver station startup
So the Driver Station is fine, but the Dashboard is entirely grayed out?
Are you using the default Dashboard or one you created?
On the Driver Station Setup tab is the Dashboard Type selected Default?
Unread 03-03-2016, 12:49
FRC #5523
Default dashboard-confirmed as such in the Driver Station.
After your post we played around and in the Driver Station we "undocked" the "Window" button and it worked!
Thank you for your suggestion.
Unread 03-03-2016, 12:54
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus and Mentor for 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Yeah I noticed that on our classmate. The werid thing is I can't change the window mode of the drive station. We are using Java to program the robot so we switched the defualt to the Smartdashboard. My guess is it is scalling glitch related to the low resolution of the classmate laptop.
FRC Drive: Play Store FRC Manager: Play Store
Unread 03-03-2016, 13:15
The Driver Station window dock controls are disabled if you use the Driver user account.
Use the Developer user account to keep them active.
Unread 03-03-2016, 14:51
FRC #5523
Thanks. That helps a lot. We never used the driver login.
