Go to Post Something has gone awry this year in FIRST. I think more teams are concerned with winning and their robot that they don't even stop to think about the kids on their team, or the learning experiences of others. - Amanda Morrison [more]
Unread 03-03-2016, 17:12
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Re: Analog Gyro .getAngle() function occasionally giving massive random values
Originally Posted by RyanN View Post
Look at your electrical connections. Analog Gyros will give some crazy numbers if they don't have a good connection.
I might be wrong here, but when you have no radial acceleration, the analog gyro should output 2.5V, then increase or decrease depending on which way it's rotated.
If the connection isn't good, the controller won't see 2.5V and will give you widely varying numbers like what you're seeing.
I've replaced the gyro, and it's still acting the same. Overall, the gyro acts normal, has a bit of drift and measures rotation fairly accurately, but every so often it'll spike, but still return to where it should be. I suspect it's software because (iirc) the gyro feeds us rate, and if we were to get a voltage spike, I doubt we'd read the same value as before the spike.
But why?
