Go to Post I implore you to not spend your mental energy on preparing your argument for the inspectors. We all have better things to be thinking about and working on. - mrnoble [more]
Unread 02-03-2016, 18:05
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Gas charged hood lifts: are they legal in 2016
We want to go to the local auto parts store and purchase gas-charged hood lifts to use on our bot for lifting our tower-scaling hook. We will be using two in series to be able to achieve the needed height. If constructed "safely", is this stored energy source legal in 2016? We are not recharging or discharging any gasses in this scenario.
Unread 02-03-2016, 18:53
Re: Gas charged hood lifts: are they legal in 2016
You may be interested in R35D.
You're also going to want to make sure that all other rules are followed, of course.
Unread 02-03-2016, 20:13
FRC #5523
Awesome!
Thank you so much. That helps greatly.
Unread 03-03-2016, 10:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Also, read the directions on the shocks. Most air springs are intended to be installed in a particular orientation (vertical, with shaft down) for best lifespan.
Unread 03-03-2016, 10:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you want a nice variety of sizes and forces, try a source such as McMaster-Carr. for gas springs. The ones used in cars are a small subset of the ones that are available. We've used McM gas springs for several things over the years on our robots, they're very helpful to reduce the load on arm drive motors, for example.
Unread 03-03-2016, 10:48
Chris is me's Avatar
AKA: Pinecone
This is basically totally irrelevant for FRC, where a gas spring might see 500 cycles on a very thoroughly driven competition robot depending on the application. You generally don't have to worry about wear on a gas spring in an FRC context, which is nice.
Unread 03-03-2016, 11:24
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Your build would almost certainly be more robust if you used two in parallel with a shorter moment arm. (Or getting a shock of the correct length as suggested above).
Unread 03-03-2016, 11:28
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
We like to demo our robot for at least the next year, sometimes longer. That said, I agree that we would not weaken a competition design to accommodate this orientation.
Unread 03-03-2016, 19:51
FRC #5523
Great idea to reduce the arm-drive motor load. Thank you. We will be keeping that in mind for future reference. For this season, we will be using bungee cords from Menard's.
Unread 03-03-2016, 20:37
MrForbes's Avatar
AKA: Jim
We've also use latex tubing to support arms...works well, comes in the KOP
Unread 03-03-2016, 20:41
Ken5736 Ken5736 is offline
FRC #5736
Ken5736 is an unknown quantity at this point
We are lifting with gas shocks. (Gas springs)
http://youtu.be/gdfB82rSGrM
Unread 03-03-2016, 22:09
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
The reason for the rod-down orientation is to keep the seal lubricated. Gas shocks have a small level of oil inside to keep the seal between the rod and case lubricated so it will not leak, and lose force.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 03-03-2016, 22:20
MrForbes's Avatar
AKA: Jim
I wonder why folks keep calling the gas springs we are talking about, by the name "gas shocks"?
strange.
Unread 03-03-2016, 22:47
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Is possible to exceed the recommended Cycle per minute value? Would this damage the them or would the life span be shortened?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 04-03-2016, 08:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I don't know for sure, but given the general behavior of gas springs, it doesn't seem likely you'll be able to run them much faster than a few cycles per minute without using greater forces than they're designed to handle. All of the ones I'm familiar with have internal flow control valves that limit the rate of motion, especially in the extension direction.
If you want to be able to extend/contract quickly, you should consider switching to regular (steel helical) springs, probably compressional. Perhaps a storm door spring could work (wrong direction).
