Go to Post Making GP a rule would be the equivalent of making a law that says you have to help get kittens out of trees. - Molten [more]
  #61   Spotlight this post!
Unread 01-03-2016, 18:09
jkoritzinsky jkoritzinsky is offline
AKA: Jeremy Koritzinsky
FRC #4786 (Nicolet F.E.A.R.)
jkoritzinsky will become famous soon enoughjkoritzinsky will become famous soon enough
Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
Can you send me a screenshot of the error?
Nicolet F.E.A.R. (Team 4786) - Aerial Assist - Programming Manager
Nicolet F.E.A.R. (Team 4786) - 2015+ - Junior Mentor
SuperScouter for FRC Developer
  #62   Spotlight this post!
Unread 01-03-2016, 20:23
jjb224 jjb224 is offline
FRC #4780
jjb224 is an unknown quantity at this point
Thanks for letting me know hopefully I can get it up and running for Buckeye Regional
  #63   Spotlight this post!
Unread 03-03-2016, 22:04
RWS98's Avatar
RWS98 RWS98 is offline
Captain of Team 2145
FRC #2145 (HAZMATs)
RWS98 is an unknown quantity at this point
This app is great!
One thing I have a question about is when I create the server I can only connect on my local network. It is using my local ip address instead of my router's public address for the server. Is it possible to use my public address?
  #64   Spotlight this post!
Unread 03-03-2016, 22:08
Originally Posted by RWS98 View Post
This app is great!
You'd have to set up port forwarding for port 5001 on your router. In theory I don't see why it wouldn't work but in practice i can't promise anything.
  #65   Spotlight this post!
Unread 03-03-2016, 22:29
RWS98's Avatar
FRC #2145 (HAZMATs)
It worked perfectly! Obviously the server application still displayed my internal ip, but I could connect using my external one.
One suggestion that I would like to make is this: Is there any possible way you could make it so the server application exports data automatically? That way I could have the server running at home on my PC and it exports data automatically to a folder (and I can have the folder on a cloud drive that I could access remotely either on my phone or on another PC while at competition)
  #66   Spotlight this post!
Unread 04-03-2016, 10:24
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Does anyone have any examples of their schemas? I am not well-versed on the creating part haha
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
  #67   Spotlight this post!
Unread 04-03-2016, 17:49
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I tried this software out today by setting up a basic schema. I was able to successfully upload and export data, but after designing a more complex schema it stopped working. Whenever I go to export data on the server, it crashes after I select where to save it. What could cause this?
  #68   Spotlight this post!
Unread 05-03-2016, 18:50
That'll take some work to get right, so I'll add that to the feature backlog for the next version.
Can you send me the schema and data files in the situations mentioned? If you have a GitHub account, you can open an issue on https://github.com/jkoritzinsky/SuperScouter4FRC with the files attached and I'll look at getting that fixed.
  #69   Spotlight this post!
Unread 05-03-2016, 19:34
Joey1939's Avatar
AKA: Joey Holliday
I did some more testing and it appears to be a problem with using two different schemas with the same regional. (Causes it to crash while exporting)
  #70   Spotlight this post!
Unread 06-03-2016, 01:25
That is supposed to be supported. I'll test that out and try to fix the bug.
  #71   Spotlight this post!
Unread 19-03-2016, 11:31
mvp107 mvp107 is offline
FRC #0107 (Team R.O.B.O.T.I.C.S.)
mvp107 is an unknown quantity at this point
My team used this scouting system at the Standish District and really enjoyed using it. It is much better than the paper system that we have used in the past. Thank you for making this. We have discovered a bit of an issue with the iOS app. We have created our schema and use both Android and iOS to scout. When we are scrolling in our schema on iOS the labels of our multiple choice fields change as well as what we have selected. I believe on the back end. the data is still there but on the front end the labels change and we loss what we selected. When we scroll the multiple choice options all shift over one spot to the left and eventually we are left with the same option across the row. Any Ideas on this?
Thanks for your help.
  #72   Spotlight this post!
Unread 19-03-2016, 13:06
Can you send me the schema? If you can open an issue at https://GitHub.com/jkoritzinsky/SuperScouter4FRC and attach the schema I'll take a look.
  #73   Spotlight this post!
Unread 22-03-2016, 15:31
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
I have noticed a critical bug that occurs for us. If you take a look at the match data, the first 2 columns are moved over. That will not work so well, unless we want to edit the csv before analyzing. I have not noticed that with the pit data at all.
I have also noticed that when adding a multiple choice question, it says text box id, instead of something like multiple choice.
Something else that I noticed, is that when exporting the data, the way that data is put into the csv is that in between multiple choice options with the allow multiple checked, all checked options are just squished together - as opposed to having a space between them. They are also not always in the same order. They are in the order that they are clicked. That could cause some issues with analyzation for some. Those are just what I remember.
File Type: zip bug.zip (684 Bytes, 2 views)
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
  #74   Spotlight this post!
Unread 22-03-2016, 16:23
Thanks for the bug report with the .zip. I'll look into it!
Any chance you can send me your schema as well?
  #75   Spotlight this post!
Unread 22-03-2016, 17:14
FRC and FTC Mentor
AKA: Adam Miller
Here is my schema. I had to zip it to allow for CD to take the file.
File Type: zip 2016Scout.zip (761 Bytes, 3 views)
Adam Miller
