Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Unread 03-03-2016, 21:49
chrisL chrisL is offline
FRC #2852 (DM High Voltage)
chrisL is an unknown quantity at this point
Grip issue when on FMS
Hi Everyone,
We are competing at GTC and are having issues with grip updating the network tables.
We are running Grip on our laptop.
When we are tethered or wireless at our practice field we have no issues.
when we connect to the FMS we are receiving image back and are processing it properly everything appears to be working properly except when we look at the network table everything comes up as a rectangle. (no values being transferred)
We also tried deploying the Grip application to the RoboRio and had the same results
Has anyone had this issue or any solutions?
Thank you
Unread 03-03-2016, 22:16
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Grip issue when on FMS
I'm not sure I completely understand the problem. Could you post the program output or screenshots of what you're referring to?
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 03-03-2016, 22:17
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Weird... Have you checked with the FTAs at the event?
Unread 03-03-2016, 22:29
Yes we have talked with the FTA and haven't been able to resolve the issue
Unread 03-03-2016, 23:12
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
What NT server address is GRIP set up to use? If you run GRIP from the command prompt, are there any NetworkTables messages printed to the command window? (you can do this by opening a cmd.exe window, changing directories to C:\Users\<name>\AppData\Local\GRIP\app, and running java -jar ui-<version>.jar). Have you opened a Network Table Viewer client and seeing if network table values are getting published there? (it sounds like it, but good to double-check)
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 03-03-2016, 23:22
Hi Peter,
When we go look at the network table when we are tethered we see all the values on the table.
When we look at it when we are connected to the FMS we receive a Null symbol.
Unread 03-03-2016, 23:29
WPILib Developer
Looking at it with what software (the code on your robot, LV Dashboard, Network Table Viewer)? What does "a null symbol" mean? The name/entry is present but its contents are blank or the entry doesn't exist?
Unread 03-03-2016, 23:36
Peter,
Correct i see the name of what its trying to publish. but where the value should be it shows a Rectangle.
Unread 03-03-2016, 23:44
WPILib Developer
I'm thinking you're not seeing a rectangle but rather a pair of square brackets, e.g. an empty list ("[]"). Since you're seeing the name it's almost certainly not a NT issue, but rather GRIP isn't actually finding what you're looking for, and thus the output is an empty list. Does GRIP show that it's actually recognizing anything (just prior to the NT publish)?
